Volks AutosEM Tuning
Results 1 to 20 of 20
    Oct 2012
    Aldershot, Hampshire
    190
    HELP!!!! Clutch master cylinder
    Hey I'm trying to get the master cylinder off of my 2.0 tdi 140. I've got all the hoses and cables disconnected but can't seem to get it off of the back of the peddle. Is it a case of shear brute force or am I missing something?
    Oct 2012
    190
    Anyone? I'm currently stuck with the peddle off and the master cylinder just sat there laughing at me 😟
    Sportback owner
    Apr 2007
    France
    464
    Patrick, according to the Haynes manual, the master cylinder is withdrawn from inside the car. Here are the instructions: Remove driver's side facia panel. Unbolt crash bar from in front of the clutch pedal. Unscrew the securing nuts and remove clutch pedal mounting bracket. Note that the upper nut is difficult to locate. Squeeze together the tabs on the pushrod retaining clip and separate the pedal from the pushrod. Release the clip and withdraw the master cylinder from the mounting bracket by twisting it anti-clockwise. Note that there are no spare parts provided by Audi. The master cylinder should be replaced completely. Hope this helps a bit.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Oct 2012
    190
    Thanks. I'm as far as I've removered everything but my hands are to big to reach down the back of the engine to twist it now 😟 just waiting for someone to pop round with some long reach water pump pliers.
    Sportback owner
    Apr 2007
    France
    464
    That's great. Now remember to twist it clockwise from inside the engine compartment.....
    Oct 2012
    190
    Got it off new one in. And the pipe connected so far. Problem now it the piston won't stay in the plastic clip that goes in the back of the peddle and the spring has now popped out
    Oct 2012
    190
    DONE!!!!!! That is really hard to do compared to other cars. Can barely fit my hand down back of the engine.
    Beagles's Avatar
    Apr 2012
    Cornwall
    86
    Why did you change your master cylinder?
    Oct 2012
    190
    The bitting point kept changing position and felt abrupt. Going to take it for a long spin this afternoon to make sure it's ok 😃
    Beagles's Avatar
    Apr 2012
    Cornwall
    86
    Mine is doing exactly the same! It did it about two months ago! It was biting and creeping forwant even with the clutch fully down! An hard to get out of 1st-reverse and in! Stopped doing it thought and now 2 months later doing it again! Had a clutch kit sat in my waredrobe for about a month now too. Sachs... Slave, DMF and clutch kit. Think It's time to fit it! But not sure if I should get the master done too? Let me know how your drive goes! Hopefully all good now!!
    Beagles
    Oct 2012
    190
    You may as well for the sake of £50. Are you getting a stage to fit the kit?
    Beagles's Avatar
    Apr 2012
    Cornwall
    86
    Where did you get yours for £50? Brand new Aswell? What's a stage?
    Oct 2012
    190
    Garage. Sorry was auto correct mistake. And I brought it from an auto factors.
    Beagles's Avatar
    Apr 2012
    Cornwall
    86
    Yes my brothers friend has his own little garage and has always done my audi and its always spot on afterwards! He's fitting the clutch and very thing for £220 famit friend so yea may as well get this fitted at the same time? Don't think I have a local auto factors... Just mill auto's and mike best!
    Oct 2012
    190
    Carparts4less.co.uk will do it cheap and deliver my clutch is playing about again so think it is deff my slave that's gone as have bled the system 3 times and it keeps goes back to normal after a while
    Beagles's Avatar
    Apr 2012
    Cornwall
    86
    Ill have a look later! Keep me posted! I would like to know how you solve this as mine needs doing too!
    Beagles
    Oct 2012
    190
    I'm trading my car in for a a4 avant at the end of the month so will bleed it again in car park around the corner from the garage and then take it in
    Beagles's Avatar
    Apr 2012
    Cornwall
    86
    Dam your lucky! Guess ill just have to get the clutch fitted then to from there and try sorting this one on my own!:/ cheers anyway!
    Oct 2012
    190
    Sorry mate. Good luck to you. How many miles is your car on?
    Graham89's Avatar
    Derv Perv
    Jul 2011
    Chelmsford, Essex
    302
    Mine was a salve cylinder. Had the same symptoms.
  1. clutch master cylinder
    By sydneyc in forum The Welcome Section
    Last Post: 24th March 2009, 22:17
  2. Clutch Master Cylinder
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2009, 10:43
  3. Clutch master cylinder or flywheel
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2008, 17:37
  4. Clutch master cylinder...
    By tommo-turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2006, 19:35
  5. Clutch Master cylinder issues.....
    By nlw73 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 08:59
