Sky InsuranceChris Nott
Results 1 to 9 of 9
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,618
    Timing Pull on an S3?
    My OBD2 Wifi Dashcommand shows 'Timing' in degrees.
    Could someone please tell me what value it should be showing? (given current state of car, see sig)
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,618
    Must be an expert on here somewhere!
    I have googled it a fair bit but still can't find the values (in degrees) that I'm looking for.
    My idle sits around -2 degrees
    Driving at a steady 50mph in 6th gear it's telling me it's +14 degrees. (it goes to +28 occasionally, albeit very briefly!)
    Upon nailing it, say 3rd gear, it pulls back to -4 degrees.
    Whats it's supposed to be on during a normal drive for example? Flat road steady 50mph?
    DeckedS3's Avatar
    Apr 2008
    South East
    550
    you want it as close to 0 all the time. I think +-5 is generally acceptable.
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,618
    I best get onto Shark then!
    Cheers buddy.
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,618
    [IMG][/IMG]
    Log journey 1^^
    [IMG][/IMG]
    Log journey 2^^
    2 x 10 minute stints, with hard fast driving and also calm driving.
    The extreme values tend to be on lift off.
    Intake G/S is slightly low, guessing the hot weather affects this alot at the moment. Will test that again in cold.
    Fear is just a word!
    Mar 2013
    Edinburgh
    214
    Hi mjr907,
    Looking at you'er graph it looks ok! You'er car should if standard pull 0-0 timing! With a file loaded on to you'er ECU it should be 0-0 but it could pull some timing too! You will only be in dangerous territory when you are pulling more then -3 timing! Everything above -3 will be potentially dangerous! Remember seeing you have done this very recently you should take the weather in to consideration and probably why you pulling 2.5 on you'er timing which is still save!
    Hope this helped!
    Mar 2013
    Edinburgh
    214
    Oh you might want to check you'er spark plug on cylinder 1.
    mjr901's Avatar
    Nov 2011
    In The Sticks....
    2,618
    Hi buddy,
    the -2.5 value is sat at idle, whilst normal driving it sits around +14 degrees. Fluctuating to 32 on lift off.
    On full power it goes to about -4 degrees
    Spark plugs should be fine. Only changed 3k ago and no miss fires reported.
    So I'm a little confused when we are supposed to read these values, at idle is it? or whilst physically driving?
    Should they fluctuate this much whilst driving? Major fluctuations happen when the excess boost is dumped.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    683
    "Timiing pull" or Correction factor is different to actual absolute timing, measured in degrees before top dead centre. Timing generally increases with RPM and decreases with Load/Boost. So, it will be constantly changing. Your readings look fine.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
  1. Knock Sensors and Timing Pull
    By Alex C in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th November 2012, 19:19
  2. skoda octavia vrs high timing pull 3rd gear run
    By vrsjaw in forum VCDS (formerly VAG-COM) forum
    Last Post: 5th June 2012, 21:00
  3. skoda octavia vrs high timing pull
    By vrsjaw in forum General Technical / How To
    Last Post: 29th May 2012, 18:47
  4. timing pull. what is a little and what is a lot
    By Matt82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th July 2010, 16:50
  5. Pulled for the first time! lol get in!
    By richy in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2004, 10:54
