Monster MotorsportVolks Autos
Results 1 to 8 of 8
    Feb 2013
    37
    A3 2.0 TDI 140, turbo/boosting problems
    hey all
    My a3 is very strange sometimes itll have loads of power other times it wont, the turbo does hiss quite a lot but heard that was common with these models?
    Anyway, say i have a car full and am going up a hill the turbo will really stuggle and on rare occasions it will cut out all together until i turn off the car completely and start it up again.
    Ive tried to see if it makes a difference when the engine is warm but it appears to be random.
    Any ideas ? thanks
    26,762
    The turbo's internal parts are getting stuck & causing overboost issues & thus gives you limp mode, so if this turns out to be the case, more than likely is, then 2 options, remove & clean or swap out for new.
    Depending where you are, we could do this for you.
    Also got a brand new turbo sitting in a box to sell.
    Feb 2013
    37
    How much are we looking at for the turbo?
    26,762
    I'll PM price for ours.
    Beware of cheap units refurbed with Chinese inferior internals, that simply are not up to the task of the boost levels.
    Feb 2013
    37
    26,762
    Forget it, its a temp solution that doesn't work very well tbh, only way to guarantee good results is to remove, strip, clean & refit or fit a new one.
    I've done number of these & the grime I've cleaned of them internally, would no way come of with this stuff.
    Oct 2012
    Warrington, North West
    960
    As NHN said, how many miles have you done? Has the turbo been changed before in its history? Might be worth a new or recon on instead of a clean?
    Feb 2013
    37
    the car has done 106k , i got it on 103k so dont know to much about the history!
  1. A3 2.0 TDI Sport turbo / boost lag / delay / flat spot
    By maffew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2013, 17:56
  2. Audi A4 2.0 tdi 140 Turbo/engine light issue
    By Leigh1984 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th February 2013, 19:57
  3. a3 tdi 140 re map problems (2010)
    By smitherz86 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2010, 19:38
  4. 2.0 TDI 140 - TURBO PROBLEMS !!
    By shilts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th March 2010, 21:39
  5. turbo boost problems
    By mike1234 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd July 2007, 13:02
