    Feb 2013
    29
    Train sound, when under heavy load round corner vibrating etc AUDI S3
    So I've been doing a lot of research on this and not getting anywhere definitive!
    Problem occurs when turning, especially right at 40/50mph. What happens is a slight vibration in the steering wheel, which you can feel through the floor slightly and a train type noise (not a bearing whirring noise). The best way to describe it is as if the wheel has been taken off and put back on without the wheelnuts tightened...!
    When driving straight it's perfectly fine, only shakes and whines when going through the gears hard in corners...
    Love to hear any ideas it's driving me nuts...
    2010 Audi S3, Rotar Alloys, Flat Bottom Steering, Rns-E, MATT white for the mean time
    Oct 2012
    Aldershot, Hampshire
    190
    Sounds like a cv joint has gone. I've got the same problem. Going to change mine tonorrow
  1. Coil light coming on under heavy braking or when brakes are pumped
    By Gazmil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2012, 08:08
  2. Any ideas ? Stuttering around 4000rpm when under load/full throttle
    By Nyteryda in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2011, 19:17
  3. Does your S3 oversteer when pushed hard round corners?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2009, 17:57
  4. Shudder when accelerating under modest load
    By slabber in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th February 2008, 11:01
  5. Rubbing sound when reversing
    By benk in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2005, 14:21
