Volks AutosMonster Motorsport
Results 1 to 17 of 17
    S3P
    Jun 2013
    16
    S3 8P Top Mounts
    Hi All,
    I'm going to be replacing the shocks in my S3 8P soon and I'm wondering if anyone can give me any advice about top mounts; there's loads about them on the 8L forum, but not much I can find for 8Ps. The OEM part looks quite different to the run of the mill rubber mounts, is that the case? Do they wear out, and should I just replace them whatever as the suspension will be out? Everyone on the 8L posts seems to rave about LCR top mounts, is there a worthwhile upgrade for the 8P, or should I just use OEM?
    I'm also fitting 42DD gearshift bushings this weekend, so I'll be interested to see what difference they make.....
    Cheers,
    Phil
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    On the S3 8p you're looking at quite a costly move there.
    Why do you want adjustable topmounts.
    The cheapest way of getting extra camber is the TTRS TCAs but adjustable mounts such as the kWs need a lot of extra suspension work.
    S3P
    Jun 2013
    16
    Thanks Alex. I wasn't really thinking of adjustable top mounts, just whether the existing ones would be knackered and whether it would be worth ordering some new ones, so I have them when the suspension comes off just in case. I just bought the car last month, so I don't know if they've been done before.
    JPK
    May 2012
    278
    034 Motorsport top mounts are very good by all accounts
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Ahhhh right I see.
    In that case replacement stock parts will be fine as I used the kW v3 suspension on stock mounts with no probs over around 30 000 miles before the whole lot was replaced.
    S3P
    Jun 2013
    16
    Sounds like a plan then. How did the OEM ones look after 30000?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Quote Originally Posted by S3P View Post
    Bit chewy.
    Those are the suspension rubber mounts after 50 000 miles below
    I replaced all of the suspension bearings with Superpro mounts and the entire suspension with kW ClubSport gear.
    S3P
    Jun 2013
    16
    That's my mind made up then, I'll get a new set from the stealer tomorrow. Was replacing the bearings a DIY job?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    Not for me!
    It means dropping the coilovers etc and if I tried it it would be messy.
    I leave it to a man who can!
    S3P
    Jun 2013
    16
    Ha ha! Fair enough, I'm no mechanic either, but I reckon I'm going to have to become one if I'm going to be able to afford all of these upgrades I never knew about before!! All of those hours watching Wheeler Dealers can't be completely wasted!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,392
    I hear you!
    You can make these cars surprisingly fast but it costs a LOT doing it well.
    S3P
    Jun 2013
    16
    Quote Originally Posted by JPK View Post
    Thanks JPK, I had a look and can't find them for the 8P, only the 8L.
    Oct 2012
    Fife
    59
    I would replace top mounts for sure. I wish i did. One of the top mount captive nuts started to spin.
    I had to cut the head of the bolt using a hacksaw blade. It was a nightmare!
    Its fairly simple to do though.
    JPK
    May 2012
    278
    Here you go: Strut Mount Pair, Track Density, Mk5 & Mk6 Volkswagen, 8J & 8P Audi - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
    I replaced mine with stock mounts and bearings when I changed my suspension, but would have gone with the 034 option if I had known about it at the time.
    S3P
    Jun 2013
    16
    Thanks, I'll definitely be looking into getting those.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    If you go with OEM replacements order the RS3 top mounts, they're tougher than the standard S3 jobbies & are slightly cheaper
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    just get some TT top mounts like Alex said , said what i got for mine stiffer and better sadly no polyurethane like 8Ls
  1. S3 Top Mounts
    By Sandip in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2008, 21:28
  2. Do top mounts need to be changed on suspension kit?
    By sharma in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2008, 23:22
  3. how hard / easy is it to fit jbs top mount?
    By edward_harris in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2008, 09:30
  4. Replacement Rear Top Mounts
    By Phantom_A4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2006, 23:24
