Monster MotorsportVolks Autos
Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By danb986
  • 1 Post By coreythorny
Thread: AutoGlym Super Reson Polish .. And..?
    37
    37's Avatar
    May 2013
    Area 51
    117
    I've used AutoGlym's Super Resin Polish without doing any research and going by what the chap said at the shop ()
    During the cleanup I realised the cloth was getting black color on it - not a lot - just light black on yellow cloth making it obvious. How much damage, if any, it would have done to the color etc? Could someone point me in the direction of what to use afterwards to protect the car's color etc? I don't want to go to websites etc - just a good workable solution please :P.
    Also - since I haven't put anything on top yet, what should I do? Leave as is and not use Super Resin again? Or am I just being cynical?
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    the living room
    3,597
    What colour is the car? Black i presume? If so i would use a wax like autoglym hd wax after the super resin, for light colours like silver for example i would use auyoglym extra gloss protection which is a synthetic sealer type wax that gives better results on light coloured paint! Dark colours wax, light colours use sealant!
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    683
    The black on the cloth is dirt coming out of the paint by the sounds of it. Modern paints are clear coat finish so don't stain the cloth like single stage used to. SRP is a very good polish, you won't damage your paint with it. How does it look after the SRP is buffed off?
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jul 2010
    561
    SRP has no cut at all, it won't be damaging anything.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,162
    If anything SRP has fillers in it not cutting compound
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    As said, it won't be causing any damaged. If it was, you'd probably see it on the paint rather than the cloth.
    Anyway, put down the AutoGlym stuff and get yourself some Prima Amigo and Vics Concours Wax
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Using a polish before waxing is a common thing to do, so what you've done is right.
    After you've cleaned up the paint with the Super Resin Polish, stick some Poorboys Nattys Blue Paste wax on it. It's designed for dark coloured cars and is awesome stuff that's so easy to use.
    I've just been put onto the Poorboys products and absolutely love them. Even in the sun and extreme heat it works great and leaves the car super slick. After washing it I rinse with a hose with no end on it and the water just sheets off so I have very little drying to do.
    R90 STL likes this.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    405
    Try claying the car first, as said SRP will never cut through clearcoat, especially by hand. The clay will remove dirt particles almost unseen to the eye which prevents you polishing the dirt into the paintwork effectively making more swirls and scratches.
    Jul 2013
    Cambridgeshire
    215
    Quote Originally Posted by coreythorny View Post
    +1
    37
    37's Avatar
    May 2013
    Area 51
    117
    Phew - it's a relief that I haven't screwed it up..
    That's exactly what I have done. Dirt has put swirls and scratches on the car.
    Are these removeable? :S
    Clay first, leave clay on and Resin polish on top or is it Clay -> scrub it and then Resin Polish? Will defo get Zymol wax off Halfords this time.
    Mar 2013
    Leicestershire
    405
    Quote Originally Posted by 37 View Post
    without seeing it you can never been certain, but I highly doubt you've scratched it lol. Will most likely just be swirls and light scratches. SRP is a good polish which with little effort by hand can offer very good results, however it's not aggressive and contains "fillers" which mask the swirls. To tthe majority this will be more than good enough.
    I say try again, (this time claying it first lol) and work with the SRP. See where you get. If you don't have much look you can then look into compounds to help remove them rather than masking.
    So pre-wash (if you use one)
    Wash (two bucket method)
    clay whilst the car is wet and using a lubricant, no need to dry after washing just rinse
    wash again
    dry
    polish
    wax
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    441
    Apologies for the hijack.
    Anyone know how to get rid of suncream handprints that have been left to bake onto the paintwork?
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Mar 2013
    Leicestershire
    405
    Quote Originally Posted by ryanstewart9 View Post
    again, a good polish will bring them out
    you could try a degreaser first
    Sep 2009
    Surrey/Hants/Berks
    441
    I've got some AutoGlym Paint Renovator, along with some Super Resin Polish & Poorboys Nattys Blue Paste Wax if that's any good?
    The car is Lava Grey in case this makes any difference?
    Mar 2013
    Leicestershire
    405
    Colour doesn't matter mate.
    Give it a good wash, then clay and try with the SRP. If that doesn't work you could try the paint renovator but I prefer the SRP myself.
    ryanstewart9 likes this.
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    564
    I hope you had the good sense to wash the car before polishing?
    As for the clay, read the instructions...
    You don't rub clay into the paint like a wax, you spray the lubricant, rub the clay over to absorb the containments & clean off.
    Then go over with your polish to cut the paint & smooth it off.
    Then put your wax on after that...
    ...... Waiting Paitently...
    37
    37's Avatar
    May 2013
    Area 51
    117
    Cheers for all the help chaps - especially coreythorny
    Quote Originally Posted by S3quatt View Post
    Course
    Jun 2013
    280
    Get yourself onto polished bliss website they have loads of products you can look up products for your car colour , have reviews on there products etc i have a red s3 and use Blackfire products its expensive but lasts for ages and the difference Is unreal (oh and I don't work for them haha ) just a mate told me about them and that's where I get my products from think I polish and wax my car more than I actually drive it these days
  1. Replies: 17
    Last Post: 28th February 2012, 17:05
  2. Replies: 11
    Last Post: 23rd May 2010, 09:36
  3. Done a little Polishing and Painting
    By Roach in forum Photography & The Digital Darkroom
    Last Post: 9th May 2008, 11:59
  4. Full Body Polish and Window polish in the NW
    By A4NA18 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2008, 16:59
