AH FabricationsChris Nott
Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By S3Alex
Thread: What's needed for stage 3 on s3 8p
    Jul 2013
    12
    Hi guys I'm stage 2 plus already just wondering what's need for stage 3 ??
    any help would be appreciated !
    thanks nick
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    Quote Originally Posted by katenick View Post
    thanks nick
    Have a read through my build thread and that will give you a stage by stage breakdown of what's required and a rough idea of costs.
    It's a bit if a read but if you have any questions I'm happy to help.
    As a starter you will need a big turbo kit which will run to £5-7k and you need to ensure you've done the brakes and suspension first.
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    424
    Quote Originally Posted by S3Alex View Post
    unless he means Shark stage 3 which is stage 2+
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    After stage 2, the whole stage thing is clutching at straws. What do you want from your car is the question? My next ugrade would be larger injectors and a Loba 400 turbo,
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jul 2013
    12
    Would like to see 400 if poss ?
    Jan 2012
    Stockport, Cheshire
    748
    Then you need the turbo and injectors
    Rick
    Jul 2013
    12
    Is that it ? No need to forge it ? Any recommendation on turbo ? Also what injectors and who to map ?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    No need for forged internals up to around 440lbs torque.
    Loba is good for around 400-440bhp
    GTX2876 is good for around 440-480bhp and anything else you need a lot of work and you'll see anywhere up to 500bhp+.
    Mapping....I used Revo but APR and GIAC also map to this level although with APR you will need their kit,and Rick,Shark and others may do as well.
    Have a trawl through my thread and any other BT threads here and be sure to choose someone who knows what they're doing.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Rick
    Nicely put.
    What its called doesn't matter,but what does matter is choosing the exact spec and what you require now,and in the future,as we all want more!
    The Loba is a very good 400+bhp choice,but if you eventually want more,it would be limited,but it will take you as far as you can go without an engine rebuild.
    Jan 2012
    469
    Just to clarify for the OP, there is a LO400 and a LO4xx turbo by Loba - the second one requires injectors and can make upwards of 400 depending on other components. The LO400 is a rework of the std K04 and can just about make 400 but has a better spool than OEM. Depends what you want, power or drivability. Alex, where does the torque peak on your turbo?
    Jan 2012
    Stockport, Cheshire
    748
    For a genuine 400 you need injectors unless you want to run it at lambda 0.95 which isn't a good idea for road engine that you want to last!
    Unless you are going to pull it apart, I'd go for the L0400 turbo. It needs a lot of mapping time to get spot on, which we are very capable of doing.
    Rick
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    Quote Originally Posted by nluk100 View Post
    Peak torque on mine is around 4000 rpm if I remember and pretty flat to over 6000.
    Jul 2013
    12
    Where can I get a turbo and injectors from. ?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    Depends on where you are in the country for who you'd choose.
    You need a good tuner who knows what he's doing as this isn't exactly a plug and play type of job.
    If it isn't done properly you can end up with a scrapped engine.
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    I'm considering going stage 3 next year. However only looking to get it up to 420-430. Is the Loba turbo going to be enough and fairly hassle free to fit? Will I need to upgrade dsg clutch too or only remap it?
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    Quote Originally Posted by RedDejavu View Post
    The LO4xx would certainly get you that sort of power.
    It's a relatively easy fit compared to something like mine but as Rick says it needs careful mapping.
    The DSG will need mapping for the extra torque but generally you do not need an uprated clutch pack until you go beyond 440lbs torque
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,470
    Perfect is revo software capable to work with this type of turbo?
    Now:
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    Best to contact Revo Kev for that.
    Revo Steve-W's Avatar
    Jul 2013
    Daventry, Northampton
    205
    Add Revo Steve-W on Facebook
    Revo Kev - eurosupport@revotechnik.com
    Jan 2012
    Stockport, Cheshire
    748
    I can supply the turbo, injectors either second hand or get them from Audi/TPS.
    Rick
    Jul 2013
    12
    Rick
    great stuff. Can you pm me a price both new and second for turbo and injectors please. Plus is this turbo and injectors off another Audi model ?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    The injectors are from the RS4..... Higher flow max than the S3 injectors although some are using Golf R injectors also.
    Loba turbos are very well made hybrid type turbos and offer a much higher flow than the stock turbo.
  1. S3 - What do i need for stage 2 remap
    By Rice in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2013, 22:55
  2. What is needed for "stage two"
    By benppl in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th January 2012, 00:24
  3. What's needed for stage 2 revo
    By quattro rob in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2009, 22:45
  4. what do need for lcr brembo's
    By Starry in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2007, 23:42
  5. What tools needed for...
    By j4g3d in forum General Technical / How To
    Last Post: 26th January 2007, 18:38
