Badger5Monster Motorsport
Results 1 to 16 of 16
Thread: Door Lock Issue
    Feb 2013
    20
    Door Lock Issue
    I have just picked up a 55 plate a3 and am having a issue with the passengers door Lock.
    When I unlock the car it don't open the passengers door.
    I open up the passengers door from the inside, then open it from the outside and it is fine. Until I lock and I unlock the car.
    Seems like the acturator is not engaging on unlock.
    Also can the auto lock feature be turned off,?
    Jan 2013
    Bolton, UK
    402
    Follow Aidy06 On Twitter Visit Aidy06's Instagram Channel
    Quote Originally Posted by Deanjames View Post
    I don't mean this to sound stupid but are you pressing the unlock button twice in succession?
    05 DSG AUDI A3 2.0T FSI BLUEFIN'D
    FULLY REGISTERED VCDS USER
    Feb 2013
    20
    Sorry just tried it, and worked
    Wicked666's Avatar
    Feb 2005
    Leeds
    582
    It's an option available to either unlock all doors or just the drivers.
    S3 Sportback
    Jan 2013
    Bolton, UK
    402
    No problem, it's one click to open the drivers door and two to open the passenger side. This can be changed via VCDS so one press opens all
    Feb 2013
    20
    Thanks!!
    Massive weight off my shoulders
    27,073
    Selective locking needs disabling, unless you prefer the option as is
    Feb 2013
    20
    Guess this is a VAG COM job I have a full version just can't find instructions anywhere to disable the feature, I hate it!
    Dec 2011
    MIDLANDS
    241
    Hi can anyone help me with this problem. My passenger door will not unlock from the outside even when the key is pressed twice. Had the car 2 years now and never done this before. It will open from the inside, and it locks fine.
    any ideas anybody???
    thanks
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    27,073
    Well it could be the handle bar that connects to the actual lock inside the door.
    When it locks, do the indicators flash?
    If not then it could be the wires in the rubber grommet between door end & pillar have got damaged & therefore not getting the signals.
    Dec 2011
    MIDLANDS
    241
    Hi this is still driving me mad. I now currently have all the door panel off but I cannot see anything untoward. The external handle bar is working the lever. But the door will still not unlock.
    i have pressed the key fob twice it won't unlock, but it will open from the latch on the inside.
    Please somebody help me!!!!!
    27,073
    Did you check the pillar rubber wires for damage.
    Dec 2011
    MIDLANDS
    241
    They don't look to have been trapped etc?
    Dec 2011
    MIDLANDS
    241
    Could it be that the motor reg assy could be at fault?
    27,073
    If the internal lever is releasing the lock, then maybe the arm needs adjusting to open the lock from the handle, but without seeing it I cant advise, could be the lock has broken for that part.
    Dec 2011
    MIDLANDS
    241
    Is there a way to test that the wire going to the lock mechanism from the motor reg module is receiving the signal from either the keyfob or the internal drivers door unlock switch?
  1. 2001 avant drivers door lock issue
    By mrnice in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st May 2013, 11:51
  2. Door lock issue
    By TwistedMind in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd April 2013, 14:12
  3. Audi A6 2001 Door Lock issues
    By paddywagon in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th September 2012, 10:14
  4. Wierd door locking issues.....
    By p14va in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2007, 13:01
  5. A4 door locks
    By jodeci in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th March 2004, 20:27
