Volks AutosSky Insurance
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By Patrick_c99
Thread: Alarm Horn Issue
    Jan 2013
    Bolton, UK
    402
    Follow Aidy06 On Twitter Visit Aidy06's Instagram Channel
    Alarm Horn Issue
    Hi, upon scanning my car with VCDS I've found this fault...
    01134 - Alarm Horn (H12)
    Checked fuses and they all seem fine, checked alarm horn via output test in VCDS and no sound. I've enabled the chirp when I lock and unlock my car but they're really low volume, you can only just hear them so I'm guessing this is tied in with this fault. Question is has anybody had this problem before and managed to solve it? I know I'm looking at replacing the alarm horn but where is it and how easy/hard is it to change?
    05 DSG AUDI A3 2.0T FSI BLUEFIN'D
    FULLY REGISTERED VCDS USER
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,826
    Hi mate! the Alarm horn is behind the O\S wheel arch liner - so it does seem a little quiet at the best of times.
    Have you tripped the Alarm (set with window down and wave arm inside after 1 minute) to see if it actually sounds?
    2009 A3 SB 2.0T DSG S line
    Jan 2013
    Bolton, UK
    402
    Quote Originally Posted by Artimus View Post
    Hi, thanks for the reply. Yes I have tried that and the alarm does not sound at all, I've done a few tests and I can't get the alarm to sound. Thinking it will need replacing but wouldn't know where to start
    Oct 2012
    Aldershot, Hampshire
    190
    Connect it to your horn through a relay and diode and then youl be able it hear it if it ever goes off
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,826
    Quote Originally Posted by Patrick_c99 View Post
    Does that work with this car?
    Did a similar mod on a previous car, but IIRC there was a post last year that claimed it wasn't possible on the A3???
    Jan 2013
    Bolton, UK
    402
    Can you repeat that in English please??? Haha
    Oct 2012
    190
    When the alarm is activated it will send a signal which used to go to the old beeper. Say that signal is only 5v. which isnt really enough for the horn. But if you send it to a relay it will act like a on off switch from the 12v from the battery direct to the horn.
    And the diode will only allow the current to flow in 1 direction so when you press the horn under normal driving it will stop any from traveling back up the system.
    Aidy06 likes this.
    Jan 2013
    Bolton, UK
    402
    Hmm, sounds interesting. Maybe something to look into if the actual alarm horn is to much hassle sorting out
    Oct 2012
    190
    Well either way you have to access the rear panel to get to the signal wire. But with the horn at least youl be able to here it. I used to park my car under my bedroom window and someone hit it one night and even with my windows open I still didn't wake up.
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    http://bit.ly/146fWVx
    The second one down is what will be wrong with your h12 alarm horn. And like others have said its behind the drivers wheel arch in a security box which is riveted to the body.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Jan 2013
    Bolton, UK
    402
    Quote Originally Posted by shariain View Post
    Let me google that for you
    Looks like I'll be staying with no alarm then, wouldn't fancy taking that job on to be honest
    Oct 2012
    190
    Ind the wire in the engine bay that leads to it and cut it lol
    Oct 2012
    190
    Actually don't. It may go off
  1. Alarm horn activation
    By mattandrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd November 2007, 23:04
  2. Alarm horn location...?
    By S3 YEA in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2006, 19:21
  3. 01134 - Alarm Horn - No communications
    By Stringster in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th November 2006, 14:49
  4. Alarm horn location?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2005, 16:44
