Results 1 to 7 of 7
    Jun 2013
    25
    7n Tow Bar Wiring + Bypass Relay... Anyone Got a Schematic/Wiring Diagram...?
    Time has come to fit a Westfalia tow bar to my 56 plate 2.0 Tdi. The tow bar itself looks straigtforward, but I could do with a little guidance reference the wiring and bypass relay - does anyone have a schematic/similar that I could follow?
    Thanks in advance.
    27,007
    Bypass relay, no relay on oem install/wiring.
    Apr 2013
    Aberdeenshire
    590
    I would think it would just be a case of grounding the relay, running in a fused supply and identifying your positive supply to each bulb and wiring them to the relevant signal wires on the relay .
    on that note what is the preferred connection method used as some people use scotch locks but I hate them I would much prefer to solder them or at a push use crimps ?
    27,007
    Do you have PDC?
    Jun 2013
    25
    PDC?
    In terms of preferred connection method... I tend to favour stripping a small section of the 'feed wire' away and jointing with solder, before tidying with shrink wrap. Heard some real horror stories with Scotch Locks, mainly due to water ingress over time, but have never experienced symptoms myself - some swear by them.
    27,007
    Parking sensors.
    Jun 2013
    25
    Ahhh... sorry. No, parking sensors not fitted, thankfully.
  1. Has anyone put a tow bar on a S3??
    By swatchuk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th April 2012, 17:34
  2. Full bypass relay kit wiring from TowEquipe
    By acano in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2010, 19:56
  3. has anyone removed a tow bar ?
    By theviking in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2010, 18:30
  4. Anyone got a spare repair wire?
    By redbutcher in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2008, 09:39
  5. Tow Bar Wiring
    By bacardi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th April 2006, 19:18
