EM TuningMonster Motorsport
    May 2012
    West Country
    172
    RNSE G, does it need coding?
    Hi, I have RNSE already I also have Audi bluetooth.
    If I buy the RNSE G version with the glossy black frame will it be a simple
    plug and play? I would quite like the voice activated features activated also.
    At the moment my voice command only works with the phone.
    Thanks.
    2009 S3 3 door. Phantom Black metallic.
    RNS-E, Tints, Piano Black inlays, Auto Lights and Wipers, Bluetooth, MFBSW,
    White Alcantara, LED numberplate lights, Black Optic Grille, Yellow Foglamps,
    K&N panelfilter, Colourmatched mirrors, S3 footplate,
    More to come....
    27,113
    You would need an sds mk2 unit, that is specific to a unit version of which I supply/fit, full sds needs wiring done aswell as coding & specific rns-e, PM if interested
    May 2012
    West Country
    172
    Okay, so assuming I'm happy to manage without voice commands.
    (Nice to have but not essential) would it be plug and play then.
    More to come....
    27,113
    Ideally it needs coding, but is pnp.
    May 2012
    West Country
    172
    Thanks for the response NHN,
    Well I'd rather have things done properly of course.
    What's the benefit of coding it if it is plug and play?
    I'm assuming it's so the ECU recognises it as 'belonging' to the car?
    I've got my eye on a 2nd hand unit, I can't justify 800-1000 quid on something that's
    nearly the same as what I already have (The Mrs won't have that) but if I can fit the
    2nd hand unit and sell my old one then the difference in price ought to be reasonable and
    worth the expense. Maybe down the line I'd like to add some extra features like reverse
    cam and tv tuner/dvd playback but first I need the newer unit.
    More to come....
    27,113
    Coding would enable systems that may not be coded for when plugged in, the main functions with be pnp but some things may not work fully or at all, your choice, at least you've been advised.
  1. Wiper motor, Does it need to be coded?
    By guysy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th April 2011, 13:21
  2. gear box oil - does it need changing?
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2010, 13:02
  3. Does the concert 2 need coding for ipod interface?
    By Garth_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2008, 15:25
  4. Does it need.....
    By CycleSi in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2007, 15:39
  5. 1.8T engine - does it need to run at idle after use???
    By a17aym in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2006, 09:52
