Results 1 to 13 of 13
    Jul 2013
    104
    Glove box door issue
    Hi guys.
    I've got a feeling this is quite common, but I can't find any threads on it.
    My glove box door on my S3 8P2 only opens half way under its own weight. Anyone fixed this? Is it a simple greasing fix, or is it pneumatic?
    27,028
    This has been discussed many times tbh, I would search a bit harder as I've personally written number of times how to fix the glovebox arm.
    Jul 2013
    104
    Just in case anyone needs it, the following link takes you to a thread, that contains all the info you need to resolve this issue, including preventative maintenance advice and part numbers for when it's too late:
    A4 owners - do this today and save yourself over 150!
    Jan 2013
    Bolton, UK
    402
    Follow Aidy06 On Twitter Visit Aidy06's Instagram Channel
    Just realised mine is broke after changing the bulb and it still wasn't working, mine has snapped so thinking of super glueing it and lubing the damper as its real stiff. Hopefully that will work rather than buying a new part
    05 DSG AUDI A3 2.0T FSI BLUEFIN'D
    FULLY REGISTERED VCDS USER
    27,028
    Superglue wont hold it, you need to use super glue to hold them together then bond round the break & up/down the parts with araldite or a 2 pack resin to make the repair hold, then grease the inside of the brake element.
    Jan 2013
    Bolton, UK
    402
    Cheers Nigel, will that hold? Have you carried out a repair before using this method?
    27,028
    What do you think lol.
    Jan 2013
    Bolton, UK
    402
    I'll take that as a yes then old Obi Wan Kenobi
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    If it's the bulb not lighting up your worried about then just pull the damper out to the extended position and leave it. Mine broke again after attempting to glue so that's what I've done for the time being. The light will be on all the time but locking the car turns it off anyway so it won't drain the battery!
    27,028
    Ironically, Star Wars is on tv lmao.
    If yours broke even after glueing then you couldn't of bonded it very well around the break & up/down the part, everyone I've repaired to date hasn't broke thus far, without being all superior about it either
    MxGaza33's Avatar
    Feb 2012
    Glasgow
    138
    I'll admit it was a quick fix, busted! It was on my things to do list with some contact adhesive but forgot all about it until I seen this thread :D
    27,028
    Its no good just adding contact to each end of parts, you need to do this aswell as encompassing with a relevant resin, adhesive etc to maintain the repair, the area of the 2 parts where they connect isn't big enough to maintain a contact repair as such, the brake arm/element is subject to allot of force with impatient people yanking them down & also the rubber drying so needs strengthening allot
    Jan 2013
    Bolton, UK
    402
    I'll have a go when I get time, it's not bothering me tbh. Glove box opens and closes just fine but was just wondering why the bulb wasn't working and noticed that the arm had snapped
  1. Glove Box Lid issue
    By mathu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th June 2012, 21:35
  2. Anyone know how to remove the glove box lid/door
    By chris_marshall in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2011, 18:57
  3. glove box door stiff to open on a4 avant?
    By chrisfrancis in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th February 2006, 22:21
  4. Glove box hinge
    By marksyms in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2004, 11:17
  5. Glove Box on New A4 Cabriolet
    By mikeramsden in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th October 2003, 18:30
