AH FabricationsEM Tuning
    6
    2004 2.0 FSI 8P Condenser fan won't switch off
    As per title really. Past couple of days the condenser fan will not turn itself off. At present stopping the battery running flat by disconnecting the battery leaving the car unlocked!
    Wondered if anybody had some ideas as to what is causing this? Any help or tips appreciated
    Apr 2013
    Aberdeenshire
    580
    If you are near ish Aberdeen I could scan it to see if its the fan it's self or sensors etc
    26,721
    This is usually a fan unit faulty, but ideally sensors need checking as per above before swapping the fan unit out, common issues are fuses, fans or a sensor.
  1. Econ light won't switch off - No Air con!
    By richiwildchild in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th October 2012, 12:24
  2. Please Help: Nearside parking lights turning on by themselves and won't switch off!
    By JohnC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th November 2011, 13:54
  3. Main fans running after switch off
    By jbcalvin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th August 2011, 21:25
  4. Aircon fan won't turn off
    By heyadamhey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2011, 04:58
  5. help rear wiper won't switch off
    By Audi_nut in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2008, 19:40
