Sky InsuranceEM Tuning
    May 2013
    16
    A3 Tdi 170PD BNM Fault code 012600
    Hi all, Don't suppose anyone can shed any light on this on. Glow plug light started to flash and flagged 012600 Intake manifold runner control deviation ( P3138 ). I assumed at first it was the control solenoid. As it said short to ground, and as it was a fairly cheap part i replaced it. All has been well for a month then the light came back on. Same fault code. I have also had the dpf light on which has gone back off between all this. DPF removal and remap is booked for for tuesday, but i need to have it tip top before i remap ideally. I have released the vacuum linkage to the runners and its nice and free no sticky spots, but couldnt be sure its connected inside the manifold.
    Any suggestions would be good.
    Ryan.
    Apr 2013
    Aberdeenshire
    583
    Dodgy flap actuator or linkage
    May 2013
    16
    Hi just seemed strange as vcds suggested short to plus intermittent which suggests electrical
    May 2013
    16
    Quote Originally Posted by rytec View Post
    Hi all, Don't suppose anyone can shed any light on this on. Glow plug light started to flash and flagged 012600 Intake manifold runner control deviation ( P3138 ). I assumed at first it was the control solenoid. As it said short to ground, and as it was a fairly cheap part i replaced it. All has been well for a month then the light came back on. Same fault code. I have also had the dpf light on which has gone back off between all this. DPF removal and remap is booked for for tuesday, but i need to have it tip top before i remap ideally. I have released the vacuum linkage to the runners and its nice and free no sticky spots, but couldn't be sure its connected inside the manifold.
    Any suggestions would be greatly appriciated .
    Ryan.
    May 2013
    16
    Can anyone tell me if the runner control is via vacuum solenoid or has a motor with position sensor in.
    Ryan.
  1. 1.9 tdi engine mount fault code on vcds
    By glenandem in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th February 2013, 20:35
  2. Audi A3 tdi 140 2005. Fault code 00926
    By Squarebush in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2012, 09:10
  3. a3 2.0 tdi BKD 8P fault codes after remap!!! worried!!!
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd April 2012, 18:24
  4. 2005 A3 TDI - pile of fault codes
    By timcoupe in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th September 2009, 12:46
  5. fault codes A3 TDI
    By Evstdi in forum Diesel forum
    Last Post: 14th February 2006, 11:35
