Monster MotorsportChris Nott
Results 1 to 8 of 8
    Jun 2013
    9
    Audi A3 3.2 V6 DSG Emission Control System Fault Light
    Hi,
    just got back from driving my car and on the way home the emission control system fault light came on, any ideas as to what this could be ?
    i've be told it could be a 90% certain its an lambda sensor if so could somebody point me in the right direction and which one i will require ( part number for example or link ) as at the moment there are a few options , such as black or brown
    thanks
    Nath
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by Tuckey92 View Post
    Hi,
    thanks
    Nath
    You should scan it to find out if it is before or after the cat on bank one or two the sensor after the cat is for monitoring purposes only
    you might find you have codes for both sensors as far as I am aware the ecu only knows the resistance is abnormal it doesn't know what sensor has the blown heater as it only measures the combined resistance.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    Get the fault codes read don't guess. Could be something silly or something more serious like stretched timing chains.
    Jun 2013
    9
    Quote Originally Posted by bmh.01 View Post
    What do I require to read the fault code ? Please Include a link
    thanks
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Vdcs have a look at the map and see if there is anyone local to you that can scan your car.
    VCDS USERS MAP
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Jul 2012
    watchfield
    50
    Depending on scanning costs you can buy a scanner to check things yourself. I've got the maxscan vag450, cost just over £30 from amazon. It's a great bit of kit for the money.
    Jun 2013
    9
    Quote Originally Posted by screechmr2 View Post
    I just purchased vcds / vagcom got this on my laptop is this ideal ?
    37
    37's Avatar
    May 2013
    Area 51
    118
    I've got a 1.6 Petrol and I've got error on Bank 1 Lambda Sensor. However, I have never seen the Emissions Light in my car. It's either something else or the Emission Light comes on when it's serious.
    The error on my car is:
    16555 - Fuel Trim; Bank 1
    P0171 - 006 - System Too Lean - Intermittent
    Freeze Frame:
    Lambda: 25.0 %
    Lambda Factor: 1.008
    Voltage: 0.440 V
    Speed: 0.0 km/h
    Lambda: 25.0 %
    Lambda Factor: 1.000
    Voltage: 0.440 V
    Speed: 0.0 km/h
    On a different note though - How much of a difference does Lambda sensor make to fuel efficiency? Is it worth spending £250 on it :S
  1. Replies: 3
    Last Post: 29th April 2013, 16:58
  2. Replies: 3
    Last Post: 1st December 2012, 22:14
  3. Emission Control System Fault
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th December 2011, 17:54
  4. emission control system warning light flashing............
    By tisinthepark in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2011, 17:02
  5. Emission Control System fault indicator
    By amimmortal in forum Diesel forum
    Last Post: 29th January 2009, 21:42
Tags for this Thread
