Monster MotorsportVolks Autos
Results 1 to 9 of 9
    Jun 2013
    Cumbria
    198
    Head gasket change parts
    Hello all, just a quick brief for those who don't know.. My car requires a new head gasket and turbo. I have decided to take these jobs on myself as a friend of mine has done many of head gaskets and timing belts so I might aswel go for it! I basically just need abit of an idea of parts I need when doing these jobs.. So for example with the turbo I need the new turbo of course but I also need to do the oil return pipe.
    now when doing the turbo does anything else need replacing?
    as for the head gasket, what needs to be changed when doing it? Baring in mind I'm doing my water pump and Cambelt at the same time. (For example head bolts or are there other seals?)
    Thanks!
    2003/2004 Audi A3 2.0 TDi Sport
    Apr 2013
    Aberdeenshire
    580
    Quote Originally Posted by Tommy53 View Post
    Thanks!
    If I was in your shoes I would have head reconditioned/skimmed maybe even your oil pump replaced but not sure if its an issue with your engine are you sure your head is ok and not cracked or porous I would get a gasket for everything you remove such as the intake.
    Jun 2013
    Cumbria
    198
    Yeah I was thinking about that but it's never overheated or anything. And thanks ill take that into consideration! Just such a hard decision as once the heads off ill be doing the Cambelt and turbo as I say and if the head is cracked it'd be a massive joke for the price :-/ but there's no hiding from the truth I suppose, it'd only go wrong down the line another time. has your cylinder head ever cracked mate?
    Apr 2013
    Aberdeenshire
    580
    I have never had a head crack on any of my cars but if the history of the car is a bit sketchy anything could have happened in its past hopefully its just the gasket though
    Jun 2013
    Cumbria
    198
    Ahh I see, and very true. Cheers for your input :-)
    tdi-man's Avatar
    Jul 2009
    1,587
    big job to set back up injectors need to be set correctly. also u will need new injector seals (not cheap) new injector bolts as well.
    make sure u get head pressure tested and skimmed.
    better of paying someone to do it to be honest.
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    Jun 2013
    Cumbria
    198
    My mates dads a mechanic and i think hes helping out too, we should be fine! but yeah i need to get the head tested etc. what companys are good for this?
    26,716
    I've got a new turbo for sale boxed.
    Boon's Avatar
    Sep 2012
    South East Kent
    338
    Really is a big job to tackle, especially as (please don't take this the wrong way) you are asking what parts need to be replaced. There are also special tools that are required too... And a DTI gauge to reset the injector rockers once they have been reseated correctly.
    Rather you than me!.... But I do quite fancy the chance to get mine apart and recon it, but then I am strange!
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
  1. 2.5 Head gasket and cambelt change
    By A4 nut in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2013, 17:34
  2. newb, with 1.9 130 loss of power after head gasket change
    By BEELZEDUB in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th November 2012, 00:56
  3. Head Gasket gone - thin caramel film on oil cap
    By VPMD7A in forum TT/TT-S/TT-RS Forum
    Last Post: 1st August 2006, 22:45
  4. 1995 S6, blown head gasket?
    By imported_BkkS6 in forum General Technical / How To
    Last Post: 6th October 2004, 17:46
  5. Head gasket wear in time?
    By FrOgR in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2004, 15:06
