Monster MotorsportEM Tuning
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By t8ups
Thread: Footwell lights stay on when headlights are on - Any ideas?
    NME
    NME's Avatar
    Mar 2011
    Near the Muller Dairy!
    146
    Cool Footwell lights stay on when headlights are on - Any ideas?
    Hi,
    Ok, so I have this new 2011 S3 which I love, but as there are so many new things on it compared to my last one, I'm not sure what is meant to be and what isn't!
    I'm not crazy right? The footwell lights are meant to go off and fade out after a few seconds right?
    I've run a VCDS scan and it shows no errors (apart from it can't connect to the Tyre Pressure Module 4C).
    Has anyone got any ideas on how to make these things turn off? They even stay on when the DRL's are the only lights on.
    I have just fitted LED bulbs, but surely that wouldn't cause this - especially as VCDS shows no errors?
    Help! It's like driving in a disco at the moment!
    NME
    NME's Avatar
    Mar 2011
    146
    Ok, Ok, so I found the menu in the DIS.
    Wow, quite a bit of new stuff in these new Audi's huh? I feel all spoilt and special with all of the new toys....
    Coming from a pre-facelift 2007 car - its like night and day in some respects!
    Hopefully any other purchasers of facelift Audi's can be spared the hassle of frantic VCDS scans by reading this post.
    Check your new DIS - its awesome.
    Jan 2012
    1,837
    My A6 does this but my retrofitted footwells in my A3 don't but I want them to as I like the dimmed glow at nighttime.
    NME
    NME's Avatar
    Mar 2011
    146
    Quote Originally Posted by a6-chris View Post
    Yeah, I retro-fitted them in my last car, and loved them once I had them, but when I got the new one, I wasn't expecting a setting where you could leave them on like you say as a dim glow. I think it might take a bit of getting used to, but maybe a low 10% setting might be ok.
    It just seems a bit weird when I've been used to all my light focus coming from outside the car whilst driving.
    Jan 2012
    1,837
    Could you post a pic of where you set them for when the car is on? ie driving?
    Can't seem to find this in my DIS, I only get a setting for when the doors are opened. Do you have a VCDS output of your instrument cluster so I can see if the software differs (which I think it probably does )
    Mine -
    Code:
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 CX    HW: 8P0 920 982 CX
       Component: KOMBIINSTR. VDO H20 0860
       Revision: D0H20008    Serial number: 2254K008000078
       Coding: 0004458
       Shop #: WSC 21860 000 1048576
       VCID: 912D4D8A88A9D6903E2
    No fault code found.
    Nov 2008
    389
    Did it definitely come from factory with the interior light pack?
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    NME
    NME's Avatar
    Mar 2011
    146
    Mine -
    Code:
       Coding: 0004458
    Hi buddy,
    It is under the same menu you have there on that picture above. When I reduce that 100% figure, it reduces the brightness of the lights in the footwell whilst my headlights are on - and it does not affect the doors or puddle lights.
    If I reduce it to 0% then they go off whilst driving.
    Mine is a 2011 model, will try and get more info when I hook it up to VCDS if you need it.
    Jan 2012
    1,837
    Thanks mate, didn't try adjusting when the headlights were on, only when the door was closed!
    Will go out and try it now.
    Jan 2012
    1,837
    Ok so tried adjusting with the headlights on, doesn't make any difference
    Not sure if it's because your cluster is newer, newer CE module or because my footwells are retrofitted, not factory.
    Jun 2011
    Wellingborough
    1,169
    Chris.
    when I get a A3 over I will look into this for you, I have retro fitted on some and this feature has been added to my knowledge.
    Trups
    a6-chris likes this.
    SLOW REPLIES BETWEEN 22nd - 30th June due to been out the office, please bare with me. Thanks
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    Jan 2012
    1,837
    Thanks Trups, will be intrigued to see if any modification can be done.
    Jan 2012
    1,837
    Quote Originally Posted by t8ups View Post
    Chris.
    Trups
    Did you ever get a look at this mate?
    Jun 2011
    Wellingborough
    1,169
    Hi Chris.
    Not had a car in to look at, well not an A3 anyway.
    Trups
    EM Tuning Lighting.
  1. How to stop dash lighting up when the headlights are OFF? VAGCOM?
    By c_w in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th January 2014, 19:00
  2. new headlights, are these any good
    By ctd in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th April 2013, 17:24
  3. HID'S ARE DIM......ANY IDEAS?
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2012, 22:53
  4. Coil light coming on under heavy braking or when brakes are pumped
    By Gazmil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2012, 08:08
  5. Help please ESP light came on and brake lights staying on when driving
    By ash1809 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th December 2011, 20:31
Tags for this Thread
