Volks AutosAH Fabrications
    Jan 2011
    226
    Anyone an expert with 8P fuses?
    So it appears that both my power windows have failed (with the windows all the way down). The car is safely in my lock up, but I need to use it.
    I know there is a fuse box at the top right of the engine bay (as you look at it) and the main one which is probably where it is is in the dash where the driver door opens.
    Does anyone know which one is specifically the electric window fuse(s) so I don't have to check them all?
    Also what kind of fuse and rating they are so I can go and buy one?
    Many Thanks
    2008 A3 1.8t FSI Sportback S-Line - Avus Silver - Full spec.
    Sportback owner
    Apr 2007
    France
    496
    I would check the following fuses in the in-car fusebox. F28 (Sportback rear windows), F23 and F38. All seem to be associated with door-card controllers, and all are 30 amp rating. Rather suspicious that both sides have stopped, since there does not seem to be a 'master' fuse for windows. If any are blown, it could be because of a serious short-circuit. 30 amp fuses do not blow easily. Anyway, worth checking them. Suggest you update your profile to indicate if you have a 3 or 5 door A3.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
  1. Anyone had probs with their indicators
    By imported_christhick in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2005, 09:47
  2. anyone have experience with wheelx.com?
    By sport99quattro in forum Other Brands & Models
    Last Post: 6th May 2004, 02:34
  3. MOVED: anyone have experience with wheelx.com?
    By sport99quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th May 2004, 01:13
  4. Anyone had problems with Koni adjustables
    By nfluester in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2004, 10:40
  5. Anyone end up with X...FEP silver S3?
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th October 2003, 09:33
