JMB RetrofitsBadger5
Results 1 to 10 of 10
    Jul 2013
    311
    s3 technical help needed guys tapping noise started !!
    hey guys , just picked up my s3 last weekend anyways i needed to get out in busy traffic before so i decided i would launch the car 4-5k revs and drop the clutch with esp /asr off and after this is noticed i have a tapping noise !!!!
    it stil does it when stationary and doesn't seem to have lost any power , i think its transmission related but could be wrong
    any usual things i should look at with them ? not to familiar with them so dont know where to start haven't plugged it into vcds yet but dont think anything will show :/ and and all help will be appreciated guys !
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    is it new? how many miles? is it modded? maybe the flywheel?
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Jul 2013
    311
    its 57 2008 75k on the clock , if have experienced a dmf on mk4 tdi's and thats more of a knock i assume these are the same
    Jul 2013
    311
    just been told on edition 38 that it could be a bent con rod :S i thought these engines where pretty bomb proof ? its a bog standard car to my knowledge did not think that kind of spirited driving would cause issues !
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,301
    Quote Originally Posted by s3_sid View Post
    I'd be surprised if it's a bent rod,especially if it hasn't been remapped,as the rods are good for 440lbs.
    The gearbox and DMF are a different matter though,and you may have damaged either.
    Jul 2013
    311
    bugger ! this guy said its happened to him twice bending rods ! i assume if its a dmf i may as well get an up rated clutch and new flywheel fitted if im looking to do stage 2+ , these cars seem to be money pits !! although i do love it the cs's sway me !
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,301
    What car did the guy have,and what sort of spec was it running?
    I don't know anyone who's managed to bend a set of 8P S3 rods once,let alone twice.
    Jul 2013
    311
    Ill see what he was running , just taken it to my local audi specialist he said it sounds like a chain or possibly the fuel pump cam follower hopefully its nothing big !
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,301
    That sounds more likely.
    Good luck
    Jul 2013
    311
    I need it ! Il have to get some pics up of it but I do have to say I love it ! Was defiantly worth waiting for one with everything in it, what's the best software to run to go for like a stage 2+ ? I know lots of people run revo any experience with r tech I know they are big on the 1.8t stuff
  1. Help Needed Guys!! Jumpstart has damaged my car?
    By Danb in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th October 2011, 08:07
  2. HELP NEEDED GUYS, PLEASEE
    By lifeboatcrew in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th June 2010, 16:23
  3. a little help needed guys
    By degsy1967 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th April 2010, 22:20
  4. Help needed. Strange metalic noise when releasing gas pedal.
    By amgad in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2010, 23:07
  5. Is this worth it, need your help please guys
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th November 2005, 13:03
