Badger5EM Tuning
Like Tree1Likes
  • 1 Post By Boydie
Thread: RNS-E DVD Read Error
    rdfcpete's Avatar
    Apr 2008
    122
    Been using the RNS-E (LED 2012) since January and the Nav has been faultless. The disc hasn't been removed from the drive since I placed it in the drive when the RNS arrived. It was an eBay purchase - Pic of the disc below.
    Just this last month it's started to fail reading the disc and produces the below error. Often I'll take the disc out, clean it, put it back in, the RNS will cycle a few restarts and the nav returns to full function. Other times it will keep cycling then reproduce the error message, sometimes mid journey which is A PITA to say the least.
    I even placed the DVD contents onto my SD card before I realised it only reads from the DVD (from what I've found).
    I've also tried two copies of the dual layer DVD disc, both by friends with dual layer DVD's and the two copies failed to read too (perhaps because it's copy of a copy...). The data on the original disc can clearly be read as it sometimes reads in the RNS-E DVD drive.
    Despite the fact I can recover the Nav operation now and again, I can't have anything less than 100% availability in the Nav.
    What are my options?
    Appreciate your pointers.
    Pete.
    Pete.
    reepers's Avatar
    Aug 2011
    Manchester
    110
    Might just need to clean the Laser buddy. Takes around 5mins! The laser is accessible by undoing the top cover from the RNSE (iirc there are 4-5 screws) remove the plastic cover over the laser and GENTLY clean it with a Slightly Moist cotton bud (the smallest amount of water known to man) - reassemble and see if it works.
    I was getting the same error few months back - did the above and all sorted! Creds to NHN from a prev post!
    A3 2006 S-Line Sportback - 2011 Facelift Rear Lights - RNSe - Cruise - Bluetooth - S5 Alloys - Auto Dimming Rear View Mirror - Akoya Silver
    Future Mods:
    - Facelift "Dumbo" Power Fold, Auto Dimming Wing Mirros
    - Bi Xenon Headlights
    - Rear S3 Valance
    - Ish -
    rdfcpete's Avatar
    Apr 2008
    122
    Quote Originally Posted by reepers View Post
    Thanks Reepers, I'll try this.
    I got to the RNS-E top earlier and don't have a screw driver small enough, is a jewelers set needed?
    Pete.
    Pete.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Cheers for the post - my RNSE unit has been acting up recently too saying to insert a disc (mid navigation), not updating the time or miles left during nav, contact audi dealer etc...
    rdfcpete likes this.
    rdfcpete's Avatar
    Apr 2008
    122
    lol - I keep getting to it, getting the unit out - then finding more screws and bottling it
    Part of the reason is I've got bit of a gypo style Aux-in install where one of the clips on the quadlock broke, so Ive taped some wires back in - don't want to knock these!
    Feels like a unit out altogether job so I'll do that at the weekend.
    Any chance a cleaning disc will do the same thing, or not?
    Thanks.
    Pete.
    rdfcpete's Avatar
    Apr 2008
    122
    Gave the laser a clean with the cotton bud (didn't feel comfortable) then ran a laser cleaning disc through it.
    Afterwards, it read the disc at first but paused and froze when trying to generate the first set of routes to an address in memory. It then failed to read the addresses from memory and on clicking display map, failed every time on each occasion.
    No better off it seems, the skitzo-reboots started again too
    It appears to read regular CD's happily.
    The nav DVD I've got does seem to be scratched - clearly not enough to fail reading 100% of the time, but enough to fail after initial first reads
    Obvious thing to try is a new Nav disc - where can I get one and how much?
    Thanks.
    Pete.
  1. RNS-e DVD reading problem
    By maars in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th September 2010, 18:01
  2. RNS-E dvd updated discs question?
    By mickel5 in forum In-Car Entertainment
    Last Post: 27th February 2007, 22:14
  3. AUDI RNS-E DVD Navigation System for AUDI A3
    By disco_stu01 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st August 2006, 18:45
  4. Sat-Nav - CD Read Errors
    By EnzoS4 in forum In-Car Entertainment
    Last Post: 24th May 2006, 16:14
  5. RNS-E DVD sat nav upgrade for facelift D2 A8/S8
    By imported_craigyjp in forum A8/S8 forum
    Last Post: 15th December 2005, 10:24
