EM TuningAH Fabrications
Results 1 to 13 of 13
Thread: MFSW Coding
    Jun 2010
    41
    MFSW Coding
    I'm looking at fitting an MFSW to my s-line a3.
    Firstly how do I know if i have the correct slip ring?
    secondly,
    is there anyone near guildford who could code it for me? (Obviously for some beer tokens!)
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    pm NHN
    Oct 2012
    Warrington, North West
    986
    What year car and model you have now? Is it dsg?
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,184
    Visit leeds2592's Instagram Channel
    Also, what wheel are you planning on adding as there are a few different types? Some'll fit, some won't.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Jun 2010
    41
    I know the wheel fits, i've had it on the car plugged in etc. Just haven't had the chance to actually get the car powered up etc! (doing a few things to it)
    So just want to check the slip ring.
    It isn't DSG no.
    Oct 2012
    986
    If you do a search it will come up with a few threads that have compatible part numbers
    Jun 2010
    41
    Where do i find the part number for the slipring?
    Fossie
    Rhubarb Triangle
    3,969
    You were asked what year your car is as that is important. Provided it is pre 2010 ish then this will help :-
    The
    ONLY steering module that will work is part number 8P0 953 549 F. It must be 8P0 not 1K0
    The correct slip ring for that module is 1K0 959 653 D which includes steering angle sensor.
    Sorry about the bold type but can't seem to remove it !
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Jun 2010
    41
    Ahh I missed that, sorry its a 2006 s-line Quattro.
    Fossie
    Rhubarb Triangle
    3,969
    If it's 2006 then you will have the correct slip ring as mentioned above.
    However, I very much doubt you will have the correct steering module. I reiterate that the steering module number above starting 8P0 (not 1K0) and with suffix 'F' is the ONLY one that will work with your mfsw.
    Both your existing part numbers can be identified using VCDS
    Jun 2010
    41
    Ok. I'm pretty much stuck then seeing as I don't have a copy of VCDS. Dammit.
    Thanks for your help Mike!
    Fossie
    Rhubarb Triangle
    3,969
    Check VCDS user map for someone in your area that will help :-
    VCDS (formerly VAG-COM) forum
    Zoom in on map for details.
    Jun 2010
    41
    Right it seems i don't have the correct steering module, yet i can't find out where the module is actually located to change!
    Any chance someone could point me in the right direction please?
    I've searched the internet but can't seem to come across any guides with a how to, to actually change the module!
  1. mfsw coding help
    By raz83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th August 2012, 21:22
  2. Can I code my radio/MFSW properly?
    By benjie in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th April 2012, 17:51
  3. MFSW Coding Help
    By Coling in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2011, 18:28
  4. Code Concert 2 for MFSW, BOSE, 6CD etc???
    By 123holah in forum In-Car Entertainment
    Last Post: 9th January 2011, 20:28
  5. 2005 A4 with Bluetooth and MFSW question - coding problem?
    By Fireyjack in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th January 2011, 15:58
