Badger5Chris Nott
    Jun 2008
    24
    Reset SRI using vcds but still shows service ??
    I reset the service interval on my 2009 S3 using VCDS.
    I used the reset SRI button and it ran through the motions fine. I choose the variable long life service from the drop down in VCDS and it stated that it completed successfully.
    The car continues to say " service due " and it still shows the spanner on the display.
    Anybody had similar problems ??
    any help would be greatly appreciated
    cheers
    Dec 2012
    241
    On mine it has 2 service reminders. One is for oil change every 12 months an a major service every 24 months.
    You have to reset both, well I'm sure that's what I did
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    Jan 2012
    469
    I had to go into the appropriate module and change the values manually.
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,088
    You need to read this thread by Gary on here, who came up with the solution for resetting the service light on later models. I followed his instructions to the letter and it reset first time on my MY10 S3. Hope this helps. Paula xx
    Service light reset - the solution
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
  1. red x is showing but still get online
    By vr6gordy in forum General Chat
    Last Post: 24th April 2012, 22:55
  2. Reset service light but not showing miles or date to next service?
    By Thacker in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th March 2012, 10:33
  3. New MAF but still low g/s in vcds...
    By SiGainey in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2011, 19:11
  4. used k seal but still a slight leak?
    By MR B A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2011, 15:10
  5. Aftermarket Head Unit but still use my Bose
    By brixo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2008, 23:49
