    May 2013
    16
    170 PD Bmn Torsion value
    Hi chaps, can anyone tell me what my torsion value should be on this engine as its reading 3.37 degrees at idle and up to temp.
    i have what feels like a slight misfire at idle and upto a about 2.5k rpm more so when cold.
    ryan
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    0-0.5
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    3.37 is a little high. Has cam belt been done?
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    May 2013
    16
    Hi Rick, yes cambelt kit and water pump fitted at the dealer 1000 miles ago. Just before I brought it. I have since tweaked cam timing and brought it down to 0.37 and is running much smoother now.
    Thanks for your interest.
    Jan 2012
    Stockport, Cheshire
    748
    Yea, dealers mess it up too...
  1. Need help changing torsion value
    By Patrick_c99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2013, 22:24
  2. Torsion value BKD ENGINE
    By vw754 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th January 2013, 00:21
  3. 2008 A2 2.0 TDI PD 170 engine BMN
    By Bedders in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th November 2012, 12:35
  4. first Time user checking torsion value
    By nokia_aid in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th April 2012, 22:01
  5. A3 Sportback 2.0Tdi (170) Quattro S-line Value ??
    By fforeggub in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2010, 13:23
