Badger5EM Tuning
Results 1 to 11 of 11
    May 2012
    Manchester
    229
    Front hub carrier help please
    I just went to change the brakes on my mates car and upon tightening the caliper back up the threads have stripped but the caliper carrier and the hub carrier is all 1 assembly, so i cant simply change the carrier. So basically i need to change the whole hub carrier assembly! The car is a 54 plate 1.6 but on ebay most of them look different and the carrier is a seperate piece. When did this change over and does this car share the same hub carrier with any other cars? any help asap would be great, thanks
    May 2012
    Manchester
    229
    May 2012
    Manchester
    229
    27,105
    Have you considered a tap to cut a new thread?
    May 2012
    Manchester
    229
    I would need a larger thread on the caliper sliding pin then surely, would a helicoil or some form of thread insert hold upto the job?
    something like this Sealey M9 x 1.25mm Thread Inserts For Vs0462 Pack of 10 Brake Callipers VS0462R | eBay
    27,105
    Sorry I just re-read, the carrier is fixed to the hub, so its not bolted on, that's a real fekker, hey if those inserts work & stay put then guess its worth a go, how bad is the thread, cause some I've recovered with taps tbh.
    May 2012
    Manchester
    229
    Tell me about it mate what a stupid design. Its quite bad to be honest I can pretty much push the bolt in and out of the thread. They look better than a helicoil to be honest because when you tighten it up it will pull the thread cap tighter. Shame I cant get a nut on the other end
    Lewis583's Avatar
    Mar 2010
    872
    Wurth Time-sert will do the job I would have thought. I've used them before on a E39 523i engine block when the headbolts stripped and they held.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    May 2012
    Manchester
    229
    Gonna go round a couple of hardware shops tommorow morning because i havent got the time to wait for delivery, if they dont have the things i posted or any time-serts will a heli-coil do the job?
    Sep 2012
    50
    its your brakes mate ! not a cylinder head bolt, if it fails it could be fatal, perhaps not to you but passenger / other motorist, is it worth it ???? no.
    get another hub/ back plate, even if its from a breakers yard
    Lewis583's Avatar
    Mar 2010
    872
    If the Time-sert is installed correctly and the bolt torqued to the correct spec, then it will be as good as new. The Time-serts are a solid metal sleeve not merely a coil of wire like helicoils.
    Caliper retaining bolts 30NM
    E39 523i cylinder head bolt torque 40NM + 180degrees rotation.
    I think the Time-serts will be up to the job.
    Edit: Though the cost of the kits isn't cheap, so as above said a second hand hub may be the more cost effective option.
    Full VCDS
  1. urgent help please re: front hub
    By S4_dan in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th December 2012, 11:57
  2. Front grill surround....Help please
    By holmefield in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2012, 12:17
  3. Front fog lights help please!!!
    By Manni.singh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th August 2011, 12:18
  4. Help Please!! Rub/Squeak/Grind from passenger front wheel/corner.
    By schwarmo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2010, 23:02
  5. Front and rear lights.. help please? :D
    By michael_muir89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2009, 01:14
