Chris NottSky Insurance
Like Tree1Likes
  • 1 Post By NHN
Thread: Help with auto lock for windows from remote please
    NME
    NME's Avatar
    Mar 2011
    Near the Muller Dairy!
    146
    Hi all,
    I have been trying to get this feature working from the remote, but it doesn't seem to want to.
    It shows as being active and "on" in VCDS, but still fails to open the windows or sun roof when the lock or unlock button is held on the seconds press and hold.
    These open if i insert the key and turn it and hold it in the lock or unlock position - but not from the remote.
    Any ideas on how to cure this, or as to what might be causing it?
    Its a 2011 s3 sportback if that helps.
    Thanks!
    27,038
    There does appear to be an issue with the coding for this feature which doesn't work, check your dis menu for any window options.
    Do not set to open as this will come back & bite you, when you sit on the key or kid etc presses buttons & the windows/roof open & then it rains or someone nicks something.
    NME likes this.
    NME
    NME's Avatar
    Mar 2011
    146
    Cheers Nigel, going into the DIS got the windows working, but not the sunroof - is that the limit of the option?
    27,038
    Try ticking box in module 09 for comfort closure of sunroof, see if it does that then.
  1. Help with part numbers for auto lights/wipers retro fit
    By rob_watti in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2012, 23:04
  2. Help with Air conditioning fault codes from VCDS Please.
    By Matt 77 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th August 2011, 20:30
  3. Can you help with some values for parts?
    By adcooper in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th September 2009, 19:03
  4. Help With Auto Lock/Close Windows Feature
    By INDIEJONES in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2008, 10:38
  5. Help with radio code for Chorus Head unit
    By mateus in forum In-Car Entertainment
    Last Post: 9th October 2007, 13:22
Tags for this Thread
