Sky InsuranceJMB Retrofits
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By mjr901
Thread: What would you recommend on servicing a 59 plate s3
    Jun 2013
    326
    Hi I've had my s3 for just under a year now very happy with it like to make sure she is well looked after I'm a bit of a freak with it tbh! Got oil, filters and brake fluid done after i purchased it, Anyways it's only covered 14500 miles but is coming up for 4 years old my plan is to change oil and filter, fuel filter maybe get better air filter? Any suggestions? Or just stick with standard ?, get the spark plugs changed, brake fluid was done last year so should be fine? Also looking through handbook and haldex oil will need done this year? I'm getting it stage 1 mapped around August when all this is getting done aswell if that makes any difference? Once it's mapped should i step up the servicing a bit? I don't do alot of Miles and I'm only the second owner first guy was like myself and he had it garaged most of the time, if anyone wondered why so low mileage. Looking through some other posts cambelt and water pump should be fine till next year? Any advice would be great thanks
    Jan 2011
    northants
    165
    to get the best out of the map i would do the big service just before the map gets done
    yes haldex oil every 20k
    pollen/bfc every 2 yrs
    i would probably fit a k&n air filter or similar
    XFi
    Jun 2010
    344
    Audi recommend replacing the cambelt every 5 years or 75000 miles whichever comes first. I thought the haldex was every 40k miles but either way it's best to get it done for peace of mind. I'd also replace the cam follower to be on the safe side.
    A stage one won't really make any difference to service intervals but beyond this people do say to replace spark plugs regularly.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,394
    Plugs are another service item.
    If you remap the car,it's well worth dropping the service intervals to 10 000 miles,and changing the plugs if you develop any misfires,as these are the first things to suffer.
    Don't stick with the standard long service intervals.....if you look at the oil after 18-20 000 miles,you'll never do that again.
    Jun 2013
    326
    Thanks for the replies, my plan was to get all this done before going for the map as I'm still not sure who or what software I'm going to use yet, yeah ill get spark plugs changed, I don't usually do 10,000 a year anyways so would prob be getting services every 6000-8000 anyways, thanks for the heads up on cam follower seen alot of posts about them once mentioned it (still trying to learn about the car) so thanks for the advice, I would rather use a rolling road while getting car tuned just to make sure it's all safe after I had problems with old car I see alot of people just get them mapped?!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,394
    Quote Originally Posted by Gfermer View Post
    That's probably true.
    The people who do all of my work(AMDTuning in Lakeside) check the car over first,then put it on the RR before mapping,and again after,and then log it on the road.
    I think most reputable companies will do similar.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,793
    Quote Originally Posted by S3Alex View Post
    Ive just had my second service now 22k. I definitely wouldn't leave it any longer than 10k intervals.
    The oil absolutely stunk, and it was that runny it was a joke.
    If you abuse it like I do, aim for 7/8k each time you drop the oil.
    Also one thing I also noticed, on first start after a oil change...what a lovely sound the engine makes!!!!! I had 1 eye open and squeeled a little bit!
    S3Alex likes this.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,394
    Quote Originally Posted by mjr901 View Post
    Agreed....mine gets plenty of love and affection on the oil front,and looks about ready for another visit soon.
  1. What would you recommend
    By Tez77 in forum In-Car Entertainment
    Last Post: 30th March 2012, 13:46
  2. Brakes all round ! what would you recommend?
    By bing in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2012, 23:31
  3. What diesel would you recommend for 3k?
    By benw123 in forum General Automotive Chat
    Last Post: 26th January 2010, 22:54
  4. Urgent: What Brake Pads Would you recommend for Audi A4 S Line Sport
    By Nza in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st November 2009, 15:33
  5. What would you recommend for a runabout?
    By jxm96c in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2004, 09:53
