JMB RetrofitsAH Fabrications
    Jul 2013
    A3 Cabriolet - no power to boot lid.
    There is no power getting to the boot lid. Therefore reversing lights, number plate light and electric boot opener are not working.
    The manual does not indicate which fuse covers this and I have checked all fuses and all are OK. Anyone have any suggestions?
    27,086
    Welcome to the site.
    Well if all of that's down, then I suspect the wiring in the gaitor on the hinge of bootlid.
    I need to check schematics for this one to see where radio wires are, but in meantime, is radio ok?
    Whereabouts are you located?
    pjr
    pjr's Avatar
    Jun 2010
    Scotland
    56
    Mine has just been back to Audi under warranty to replace the loom between the bootlid and the body - mine started with a reverse light not working, but inside the rubber gaiter there was 1 broken wire (reverse light) and 4-5 others with the insulation rubbed off.
    Was told there was a modified loom to stop it happening again.
    My car I'll be 3 years old in September, 24k miles - local dealer didn't expect to see a fault like this on a car of this age.
    image by Paul_J_Russell, on Flickr
    Current - 2014 VW Golf GTI (220PS) - Tornado Red
    Previous - 2010 A3 1.6TDI Sport Cabriolet - Brilliant Red
    27,086
    Yeah that's what I expect they will find tbh, not enough slack in the cable.
    Jul 2013
    Finally got an answer from Audi dealer that there is NO fuse covering the tailgate electrics, so had a look inside the rubber gaiter and sure enough the thick brown wire was broken. A couple of other wires had broken insulation. Extended the brown wire and all OK.
  1. 1st problem no power to boot lid
    By bez101 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th May 2012, 19:18
  2. Rear lock plinth on boot lid (rust)
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2007, 20:26
  3. Rear boot lid spoiler
    By Lynas in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd February 2006, 21:15
  4. ETKA diagram needed for boot lid
    By cybrey in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2004, 11:54
Tags for this Thread
