AH FabricationsSky Insurance
    Jul 2013
    21
    wrong haldex oil should i keep driving?
    Hey guys I recently had a second hand diff and controller installed on my A3 however the new unit also wouldn't work, doing a further investigation the garage admitted they only put gear oil in and not haldex oil which has annoyed me, when I turn the car on I hear the pump making churning bubbling noises for about 5 seconds and then it shuts off I've also only got fwd, should I avoid driving the car as I don't know if this oil is going to cause damage to the unit?
    27,129
    Depends on the viscosity etc tbh, they should of used the correct type regardless what they thought was best, they need to do it correctly & see if its ok then, if not then you could tbh challenge them it was a working system when bought & now its not, that's your choice.
    Jul 2013
    21
    Well my problem is that my previous system had failed and they where installing a second hand one, I was recommended to take it to this guy through a friend as he once worked for vw (I can see why he doesn't now) but he's telling me the new unit is a dud however I caught him out when questioning the haldex oil. I can't do much with the car until Monday and I'm going to be doing about 40 miles in it until then do you think its safe or will I be risking damaging the unit even more? Gear oil is 75/90.
    27,129
    I wouldn't drive it with a fault, you could do more damage than current.
  1. haldex oil
    By derickcos in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2006, 15:14
  2. Haldex oil change temperature
    By AndrewB in forum General Technical / How To
    Last Post: 15th December 2005, 11:18
  3. What should the misses drive?
    By dazzatdisport in forum General Chat
    Last Post: 13th November 2004, 17:55
  4. Haldex oil change
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2004, 09:32
  5. Haldex Oil Change
    By ZAF in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2003, 14:50
