Results 1 to 11 of 11
    SCHOLESY83's Avatar
    May 2012
    42
    Can I test my Oem diverter valve? (Dump valve)
    Hi,
    got the flutter sound happening when letting off the throttle, so took my diverter valve off ready to replace with new one. Is there a way I can perform a check on my old one? I've noticed these are electronically controlled and not working off a vacuum hose as I used to see in turbo cars.
    cheers.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    yes pull the top off and check the rubber for splits damage
    SCHOLESY83's Avatar
    May 2012
    42
    Did that, rubbers fine? So does that mean the valves fine? Why else would I be getting this flutter noise all of a sudden when I lift off throttle?
    bez101's Avatar
    Jul 2008
    8,534
    with out hearing it i cant say
    have you got another DV to try ?
    Sep 2012
    85
    I'm on stage 2+ and every time I change get it sounds like a turkey is underneath 😆 I didn't do it on the stock map
    bez101's Avatar
    Jul 2008
    8,534
    what air filter are you running ?
    2+ will kill the non revised DV prety quick
    Sep 2012
    85
    I'm running the neuspeed p-flow, I have the revised dv one of my first mods
    Jan 2009
    125
    My car makes a dump valve type sound on gear change/lift off, i'm running ITG CAI. From what i've read it's normal. My old Evo did the same when i was running the standard DV.
    Running the Rev G DV.
    S3 Revo Stage 2+
    Milltek Non Res-ITG-Autotech HPFP-Loba SMF
    SCHOLESY83's Avatar
    May 2012
    42
    Unfortunately no, I've had to order a new one from Audi. But concerned this valve may not be the fault
    SCHOLESY83's Avatar
    May 2012
    42
    Is there a way i can test the operation of this valve and make sure the solenoid is working, plug it back in whilst unfitted and start rev the car? or put 12volts across the terminals or something??
    Mar 2013
    155
    log with VCDS and check diagnostic it usually brings up 'Faulty DV' or similar wording
  1. Diverter Valve, Dump Valve or Forge Splitter?
    By tom792 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2011, 21:53
  2. Blow off valves/Dump valves
    By TRANZFORMA in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2009, 14:03
  3. Blow off Valve/Dump Valve
    By Mason-A3Sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2009, 18:41
  4. Best Diverter Valve/Dump Valve
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2003, 13:11
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
