JMB RetrofitsChris Nott
Thread: AVS Servicing
    Aug 2012
    Aberdeen
    42
    AVS Servicing
    All,
    Have done a couple of searches through the forum just to find out a bit more about AVS servicing.
    Mainly, is it purely based on mileage or are there other factors to determine how long until the next service. i.e. magnetic sensors to detect oil quality or any other data used?
    Since I bought the car I have been on AVS servicing and in the last year have done around 10k miles. The dash says I have around another 3.5k miles until I need to service. I always use the correct 507.00 top up oil if needed. Also wondering if AVS servicing is worthwhile or should I just service it regularly every year?
    Chris
    2.0TDI 56 S-Line if it makes any difference
    27,099
    Personally I stick to 10k, longlife 20k for me is far to long for oil to run in the engine, at the end of the day if you want longevity, then lesser mileage services will always be better.
    Aug 2012
    Aberdeen
    42
    Thanks for that. While on the subject, how does the variable servicing work. Is it dependant on Engine speeds etc as well as mileage?
  1. How Expensive? - Second AVS Service
    By james_suckling in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2004, 09:20
  2. AVS Service Cost
    By DRESTER in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2004, 11:07
  3. s3 avs servicing
    By viper in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2003, 08:26
  4. S3 AVS service costs
    By batty in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2003, 20:23
  5. 2nd AVS Service - How much?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2003, 15:31
