Sky InsuranceEM Tuning
    Jan 2012
    1,601
    Engine Start Blocked by Immobilizer .. Huh?
    Okay so started the car this morning heading to work, immediately the car died and the glowplug light started flashing.
    I didn't have time to do the scan (it was 3am!) but I knew something would be stored so scanned it this afternoon.
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 056 S HW: 03G 906 021 AB
    Component: R4 1,9L EDC G000SG 2917
    Revision: --H09--- Serial number: --
    Coding: 0000071
    Shop #: WSC 06314 000 00000
    VCID: 37795312468DA8A0D11
    1 Fault Found:
    005488 - Engine Start Blocked by Immobilizer
    P1570 - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 113880 km
    Time Indication: 0
    Date: 2013.07.02
    Time: 03:18:17
    Freeze Frame:
    RPM: 966 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.16 V
    Bin. Bits: 00101100
    Bin. Bits: 11000000
    (no units): 33.0
    Readiness: 0 0 0 0 0
    and
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Part No SW: 8P0 920 982 CX HW: 8P0 920 982 CX
    Component: KOMBIINSTR. VDO H20 0860
    Revision: D0H20008 Serial number: --
    Shop #: WSC 00899 210 85177
    VCID: 912D4D8A88A9D6903F5
    00883 - Ignition Switch (D) Terminal S 012 - Electrical Fault in Circuit - Intermittent
    This has never happened before, anyone else had it?
    New battery in the key but if the ignition switch/barrel is faulty it will be covered by Audi warranty.
    17978/P1570/005488 - Ross-Tech Wiki
    00883 - Ross-Tech Wiki
    Re the 00883, the car has none of those symptoms?
    Aug 2012
    Essex
    72
    my mk4 golf once done the exact same thing, glow plug light flashed and wouldn't start, not even cranking. I was stuck at work so I kept trying and eventually it worked like normal, never fixed it as it only done it once and never again, though i did swap the key for the spare!
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,928
    fault from transponder to car
    nothing to do with battery in key
    prob just gremlins
    Jan 2012
    1,601
    Thought this was a red herring, it seems not.
    Happened again this evening, this time the car didn't start and died at 500rpm when starting.
    Will get it booked in and checked out.
    May 2012
    RETFORD, NOTTS
    1,706
    Are you local? i could check your transponders are sending and recieving signal. more likely a sticky relay or switch unless the cluster is on its way out.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jan 2012
    1,601
    I'm in Belfast which is a bit far from you!
    Can it be checked via VCDS? If so how?
    The car is still under warranty so should be covered.
  1. RS4 Engine start button on S3
    By klik in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th June 2008, 18:32
  2. Engine start button from RS4
    By terrymcg in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd June 2007, 21:49
  3. remote engine start
    By mcmasman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th April 2007, 14:07
  4. A8 Engine starts, runs for 2 seconds then stops
    By tallmat in forum A8/S8 forum
    Last Post: 29th November 2004, 11:55
  5. Engine start?
    By imported_YOGi in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2004, 01:07
