Thread: Limp mode??
    Nov 2012
    53
    Limp mode??
    Hi all,
    After fixing a couple of leaks in my exhaust system the weekend I took it out for a spin to hear the vastly improved sound. The second it hit 3krpm limp mode struck and I hobbled home like an injured sparrow.
    Few details - Exhaust is a milltek decat/downpipe followed by a straight through pipe. Car is a 2007 2.0tdi, and I did have a quick go at spraying some oven cleaner on the turbo to eliminate sticky vanes (a noticable amount of cr@p came out the back but not plumes and I've always used premium diesel + redex to keep everything as clean as possible).
    Any ideas? I'm currently charging the laptop to see if I can get VCDS on the badboy.
    Thanks,
    Nath
    27,079
    Only true way to clean the turbo is to remove it & strip it down tbh & maybe use a dremel with metal brushes & maybe brake cleaner to get it back to stock metal that is.
    Scan 1st for the limp reason, then if its overboosting etc then turbo is your 1st port of call.
    If your turbo does have an issue, we have a bkd 2.0 tdi new turbo available.
    Nov 2012
    53
    Ok, thanks for the quick reply.
    Also, while underneath the car noticed what looks to be oil around the intercooler pipes? Am I right to assume the worst?
    27,079
    That's normal unless you have a catch can, can remove pipes, clean up & refit, it will come back.
  1. Limp Mode/MAF Problem????
    By GarryX in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2005, 11:10
  2. Limp Mode
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd February 2005, 09:55
  3. limp mode due to inlet manifold pressure HELP !!!
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th January 2005, 19:39
  4. Going Into Limp Mode
    By johnboy1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2004, 17:55
  5. N75J and limp mode (overboost problems)
    By pure in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2004, 18:52
