Results 1 to 10 of 10
Thread: Starting probs
    Jul 2013
    7
    Starting probs
    Pls help bought a3 2.0 fsi 2004 reg about 4 months ago .All fine for couple of months then started playing up on warm start ,cold start fine .Got so bad RAC called to recover me to local garage ,scanned car said it was crankshaft sensor so got that changed all good for week then problem came back .Took it back said starting motor sounded rough so had bearings replaced on starter motor .2 days problem back ,next step check and regap plugs .Fine for another 2 weeks then problem back only this time will not start at all not even turning over now ,turn key nothing pls help love the car but getting fed up now.
    Apr 2013
    Aberdeenshire
    590
    Quote Originally Posted by Leoncm View Post
    it could be a few things like a fuel issue or possibly a engine coolant temp sensor but you really need to have your car scanned to sav the guesswork
    Oct 2012
    134
    When did it last have a new battery?
    Solved my starting issues despite the battery testing fine down at the local battery place. These cars are particularly fussy it seems.
    Apr 2013
    Aberdeenshire
    590
    Quite agree I need to replace mine it failed the load test but starts ok but I think I could be responsible for some of my niggles dam it's only 8 years old.
    Jul 2013
    7
    Had battery and alt checked all fine.Had car scanned crankshaft sensor fault had that changed.
    Apr 2013
    Aberdeenshire
    590
    I don't think a dodgy/ miss reading cts will generate a code I would get a graph run or just change it as they are fairly cheap and very easy to replace or could run a graph of it on vcds .
    Oct 2012
    134
    Quote Originally Posted by Chillout View Post
    Get a Varta Silver in there. I went from being so unsure as to almost not order the thing to being totally gobsmaked when I installed it. Can't believe the old battery was supposed to have been OK. Starting was totally transformed.
    Sort it now before it fails. Saw a German couple just yesterday in a carpark with a 2005 A4 with an AA man trying to jumpstart them.
    As for 8 years, my battery was only 4 years old! Another shortlived piece of Bosch kit in a VAG car!
    Jul 2013
    7
    Thanks will look into the battery side of things later in the week.Will post any updates
    Jul 2013
    7
    It turns out the problem with the non starting was a broken retaining clip on the cable to the starter motor.
    Sep 2013
    Norfolk
    I have a similar problem with my 2003 A3 2.0FSi. Starts from cold fine but as soon as the engine is warm it will take 3 or more turns to fire and runs lumpy for a second or two. I had 3 fault codes recently, the camshaft position sensor, the oxygen sensor and the crankshaft position sensor. Replaced the cheapest (camshaft sensor) but problem still persists. Hope it isn't the NOx sensor because they're £500+!!! Recent work has included: new rad, water pump and cam-belt. On another thread I did have a recommendation that I replace the crankshaft sensor. I'm reluctant to pay for a scan if the results aren't definitive and can't be relied on. Can anyone explain how a broken clip on a starter motor cable can affect starting only when the engine is warm / hot?
  1. 99 A4 tdi starting probs
    By Maverick1888 in forum Diesel forum
    Last Post: 12th June 2010, 18:39
  2. A3 starting probs
    By sahz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2009, 19:40
  3. s3 starting prob
    By s33jdt in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2009, 22:08
  4. A6 4.2 v8 starting probs?
    By 8cylinder in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th April 2008, 20:04
  5. 1.8T starting probs
    By keendean in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2005, 21:25
