Chris NottEM Tuning
Results 1 to 10 of 10
    Apr 2013
    Kettering, Northamptonshire
    171
    2.0 TDI ran out of fuel
    Before you say you should let it get below a quarter of a tank my finances are very tight at the minute, what's the procedure to bleed the air out? I have vagcom, I've filled the fuel filter housing right up but no joy, took the rocker cover off but doesn't look like the injectors can be cracked open?
    please help!
    Mar 2011
    Cleveland
    874
    You should just churn it over and it will start in a minute or so.
    According to the handbook!
    TDI140's Avatar
    May 2011
    1,293
    Dont need to do anything just put fuel in and turn key until it starts happened to my van once minor mishap
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    as above crank till it starts
    J8TT X's Avatar
    Jan 2011
    Leicester
    327
    Happened to me (well the mrs) she just got to petrol station when it stopped, she put diesel in but it wouldn't start.
    AA came and manually bled the air out.
    Sorry I cant be more specific or know what they did exactly, I wasn't there at the time.
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,358
    most modern dervs just need lots of cranking, problem is if your battery isn't capable you;ll need a tow or jump start
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,162
    Always thought you had to drip start a diesel
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Apr 2013
    171
    All sorted now thanks for the advice, it drained my battery pack and took loads of cranking from a van, started to worry when it started coming up with oil pressure on the DIS
    Aug 2012
    110
    For common rail diesel this is not good advice due to much higher fuel pressures you can damage the fuel pump, need to enter VCDS to activate the fuel pump to prime the system. On older PD systems then just turning over till it starts is the normal procedure and hope enough juice in battery.
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    873
    Omg I'm gonna be more careful, didn't know I could cause myself unnecessary ball ache. I've cut it close quite a few times driving around with the DIS reading 0 miles.
  1. Coolant ran out
    By Chris128 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2009, 15:14
  2. I ran out of talent!!
    By S3 Big Andy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2009, 20:14
  3. A4 TDi cuting out!
    By leerally in forum Diesel forum
    Last Post: 30th October 2007, 08:53
  4. Re: Ran out of fuel......help.
    By halfcab in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th April 2006, 21:09
  5. Ran out of fuel......help.
    By halfcab in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th April 2006, 20:01
