Monster MotorsportChris Nott
    Oct 2012
    Warrington, North West
    986
    Benefits of fitting a catch can?
    as title, its been on my mind a bit lately, would it be worth the 25-40 quid? my vehicle is a 2tdi bkd engine
    also spotted this kit, Black OIL CATCH TANK PCV + Fitting Kit Removes Sludge | eBay
    May 2013
    202
    Quote Originally Posted by Mikemc View Post
    I opened a thread recently about this very issue. Most people believe that I it better for the engine/oil and should be fitted as standard. From what I see they do stop a lot of crap going back in to the engine. Only reason people believe it is not fitted as standard is because car manufacturers probably and rightly think the general public would forget to empty the can causing them to overflow or burst in freezing conditions. With most things you get what to pay for. I would suggest buying the REVO or FORGE Catch Cans but they are lot more that £40. I am more than likely going the REVO route but that's because they are hopefully going to do me a "package deal" as I want a few bits, so I am hoping for some sort of discount.
    Is an uprated DV and Oil Catch can really required?
    Oct 2012
    986
    Quote Originally Posted by wanton View Post
    It was your thread that refreshed my mind, have you got a link to a revo or forge catch canister?
    May 2013
    202
    Goggle is your friend. All easy to find
    STaSIS Revo Performance Online Shop. Revo Catch Can For 2.0T FSI
    this is the Forge unit if you have the "Charcoal filter" in your car Forge Motorsport | Alloy Fabrication
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,320
    The problem with the TFSi scavenging system is it dumps a lot of oil and water vapour into the inlet manifold,where it builds up on the inlet valve stems,as the direct injection system doesn't inject petrol into the inlet above the valves.
    A catch tank will remove a good bit of this,but not all,as there is a cam cover breather that empties into the turbo inlet.
    So....it reduces the problem,but doesn't negate it altogether.
    May 2013
    202
    Quote Originally Posted by S3Alex View Post
    As per usual Alex thank you for the proper explanation! Does a "PCV Fix" sort out the cam cover breather so it doesn't empty into the turbo inlet? Or is it just an addition for the Catch Can to work?
  1. Guide - How to fit a catch can and simplify the PCV system
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2014, 17:49
  2. Quick check before i fit my catch can...
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2013, 17:16
  3. Forge Catch Can Kit Fitted Today :D
    By david_phillips95 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2012, 11:51
  4. Anyone fitted a Catch Can?
    By twist123 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 23rd October 2012, 15:05
  5. BSH CATCH CAN FITTED TODAY.
    By G"MAN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2009, 18:46
