Sky InsuranceJMB Retrofits
Results 1 to 8 of 8
    Jul 2010
    561
    A3 key fob - can I replace the external case?
    I have the older style rounded key fob, is it possible/easy to buy a replacement part off ebay and switch the blade and electrics over?
    Mine has got tatty over the years.
    Dean_T's Avatar
    May 2004
    West Mids
    523
    No idea if you can replace the actual case but you can buy covers;
    VW Seat Skoda Flip Key Case Cover Car Silicone Skin Rubber VAG Passat Touare (57 | eBay
    I dont have one myself but stumbled on them some time back!
    Dean.
    May 2012
    RETFORD, NOTTS
    1,753
    Can you take a photo of your key? So long as you swap transponder over and resync if its a remote should be ok. My new key was about 40 complete though.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jul 2010
    561
    27,096
    The immo chip is in the top half & its glued in place, you could remove, but risk breaking the glass, your choice but overall yes its possible to swap parts across & if you swap the pcb over within a limited number of minutes, it should hold the remote settings, anything afterwards & needs resyncing with vcds ideally.
    May 2012
    RETFORD, NOTTS
    1,753
    Yep as NHN says, the glass chip is easy to break, personally i would use this as an opertunity to buy a new extra key and keep the tatty key as a functional spare.
    Mar 2011
    Cleveland
    979
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    300
    Add craigynett on Google+
    if your remote uses a cr2032 battery then yes it will fit. If you decided to go for a full new remote then with your model you can use the newer style 1 piece A3 remote
    Please contact Admin if you wish to advertise your business/services on the forum
  1. HELP WITH OPENING THE REMOTE KEY FOB TO REPLACE KEY PAD
    By shady-ninja in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2013, 08:40
  2. Key fob ,can I check if signal produced
    By bob2312 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2013, 10:18
  3. 2002 S3 - can I replace the Symphony 2 but keep the BOSE?
    By its_neil in forum In-Car Entertainment
    Last Post: 29th March 2010, 22:06
  4. open and closure of the windows with key fob-S3
    By stressfrees3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 13:44
  5. can i just replace the sensor on the maf filter?
    By shufti in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2006, 09:22
