AH FabricationsChris Nott
Results 1 to 14 of 14
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    VCDS Walkthrough to changing service intervals?
    Hi, having trouble with resetting the service intervals on my 57 A3 2.0 TDI, serviced it today and turned the ignition and it is telling me another service is due in 22 days/6,300 miles. The miles I'm not too fussed about, but 22 days... I don't want to have to reset it every 22 days.
    Had a search and tried all the mentioned methods but still stays the same.
    May 2012
    RETFORD, NOTTS
    1,753
    Use the sri reset function, the drop down menu of available options is very self explanitary.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Apr 2012
    UK, Portsmouth
    601
    Tried that and tried fixed service and flexible service and even coded the miles/days manually and still no joy.
    May 2012
    RETFORD, NOTTS
    1,753
    Do you have a genuine cable? its worked every time for me, although there was a guide i think on rosstechs web page to do it manually.
    Apr 2012
    UK, Portsmouth
    601
    Yeah it's a genuine cable. Must be doing something wrong. Ill try again this afternoon.
    Oct 2012
    139
    Quote Originally Posted by chris.vincent3 View Post
    Did this myself last week. Seems to be trial and error I'm afraid.
    Do an error scan as well. First time I coded it the supposedly correct way I created a fault. Took different combinations of the interval reset to clear the fault and also get the right info into the service display.
    May 2012
    RETFORD, NOTTS
    1,753
    are you doing it manually in the engine and measuring blocks? I always use the SRI reset application at vcds start screen
    27,121
    There does seem to be some issues with some newer 08 etc cars with sri feature, best to search the forum for the manual process, this works fine.
    Jan 2012
    SW London
    794
    have u tried the normal reset via the button on the dials? the other thing is u may need to enter the values into what i think is the 3rd column which has "--" if i remember right. e.g it may say 6,700 miles, u have to change it to 12,000. if it says 22 days, change it to 365 days
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    c_w
    1,061
    The auto SIR doesn't work for me either on my 57 TDI 170, not for "service due" warning anyway. I end up going through all the service indicator settings manually in the instruments(?) module.
    Apr 2012
    UK, Portsmouth
    601
    Starting to frustrate me now, after using VCDS a bit more today the service light decided to come on constantly now, so went to the old fashioned way of the process of the knobs in the dash, that doesn't work either, a few processes that I've found and the previous process that I used last time I serviced it doesn't work.
    Went through the service life on the DIS and the values are correct on the DIS, its just the reminder that comes up upon ignition.
    Whole point of a service bong is to annoy you into getting it serviced, now it is serviced it is still bonging at me..!
    Here are my values.. Can anyone see anything obvious that is wrong?
    c_w
    1,061
    Can't remember which one takes it off but go through them all resetting them even if they're on the correct setting. Isn't there another one further away from the main bunch of service settings? (Still within that module).
    At a guess it could be the Day Counter? Or is that how old the car is!
    Apr 2012
    UK, Portsmouth
    601
    Quote Originally Posted by c_w View Post
    Its channel 02, set value to 0 to turn SRI off and 1 to set it on. I've tried setting it to 1 and then back to 0 and that didn't work.
    As for day counter, that is correct the age of the car.
    Apr 2012
    UK, Portsmouth
    601
    After trying numerous methods of resetting the light, I tried VCDS again and clicked the "Reset service light (Canada Only) and hey presto, it's got rid of the light and the service interval next is what I wanted it to be too.
    Has this been reported to Ross Tech do you know NHN?
  1. Do we change glow plugs as part of a service/interval?
    By RobMorris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2012, 01:52
  2. Changing service interval type (variable to fixed)
    By mattpanton in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th August 2011, 18:28
  3. Changing SRI Service Interval
    By defsix in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th February 2011, 23:29
  4. Changing DIS from variable to fixed service intervals
    By Monsoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th July 2006, 12:39
  5. service intervals
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2003, 12:42
