Quick VCDS Query
dan77
dan77
Down south,
Just scanned my car and it came back with these faults which wont clear
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H03 0040
Coding: 188000187F28850D489AC63300
Shop #: WSC 06314 000 00000
VCID: F9FCF842B06B79D0E62
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
01565 - Luggage Compartment Light (W3)
007 - Short to Ground - Intermittent
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H52 0100
Revision: 02S Serial number: AUZ2Z3F3499798
Coding: 0001001
Shop #: WSC 06435 000 00000
VCID: 326E8F6EAD9DCA88E78
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 4
Reset counter: 99
Mileage: 103907 km
Time Indication: 0
Date: 2013.05.25
Time: 17:18:15
The boot light seems to work fine so I'm not fussed about that but the radio reception doesn't seem great, just wondered if anyone could point me in the right direction for a fix?
Did you retrofit the rns & what radio was in there before if you did.
Boot light is probably an led unit now?
Thanks for the fast reply, boot light is indeed an led unit, i dont have rns just the standard single din concert
Sorry stupid me, it states part number of radio in log, been a long **** day with allot of technical issues to work through, for once not with cars lol.
Then check the connections on rear of radio & also have you had any issues with leaky wiper motor, may have dripped on the amps in boot lid, remote but if connections are ok on radio then I would look there next.
OK thanks ill have the radio out over the weekend sometime then, the rear was always seems to have been ok, might take te trim and have a cursory glance in there just incase,
716
6
750
492
7
551
