AH FabricationsBadger5
    Oct 2008
    17
    2.0 TDI throttle body stuck open
    My 55 reg TDI sport was making funny noise, so took it to my local garage and the plugged it in to computer, code pointed to throttle body stuck, they dropped pipe and confirmed valve stuck open.
    so I will replace, have taken the valve off already and part number 038128063G, do I need the very same number as I see some end in different letters? also noticed it was a bit oily in the pipe to valve and vale it's self, is this normal?
    links to cheapest valve appreciated too.
    BENJAMIN's Avatar
    Mar 2011
    472
    Wrong section of the forum dude. However you'll find that your fuse has blown for the overrun shut off. It's a 10amp fuse in the engine bay fuse box. Problem fixed.
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    Oct 2008
    17
    I did read about fuse blowing, but if it blew then the motor most probably has a short. Will check the fuse when I replace, not sure about it being oily?
    Insult to injury I broke the clip on the 4 pin connector that on the loom, doh! Will use zip ties to hold it in place if I can, couldn't find any connectors online and would need a pin tool.
    tdi-man's Avatar
    Jul 2009
    1,612
    I have for sale if you need one in good working order
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
  1. 2.0 tdi 140 rough idle EGR valve throttle body
    By maffew in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2013, 19:58
  2. Replies: 5
    Last Post: 28th February 2011, 19:16
  3. Align Throttle Body (Manifold Flap) on Audi A3 2.0 TDI.How ?
    By kaz219 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd September 2008, 20:50
  4. Throttle Body
    By darrenp in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2004, 12:33
