Badger5Monster Motorsport
Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By ApolloS3
  • 1 Post By wuta3
Thread: S3 revving on its own when idle, and high pitch whistle when driving
    ApolloS3's Avatar
    Jul 2012
    Newport, South Wales
    73
    As in the title, my S3 suddenly started making one hell of a whistle noise when driving this morning, down the motorway, its so loud i can hear it from inside. when its at ~1000-3000 revs its most frequent.
    When i get to my destination, and put it into neutral (or just depress the clutch), it starts doing this...
    (annoying kid on trampoline in background in case your wondering what the other sound is)
    Under the bonnet...
    Also worth noting the noise about 4 seconds after starting the engine, and 4 seconds after switching off...
    Some friends and most internet diagnosis is looking towards the PCV valve and / or hose, or fuel pressure sensor.
    It is booked in for a major service and cambelt change, however this only started happening today, on the way to a quick KFC lunch...
    As im looking at around £700 for cambelt + service, I could do without another big hole in my pocket.
    Thanks for any help,
    Jordan
    EDIT*** Ive lost a good litre of oil in about 2 weeks... ive read that if the PCV valve is broken, it forces oil out and causes oil leaks?
    KrAzY K likes this.
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,075
    Vids say they are private. Check your settings
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    wuta3's Avatar
    Jul 2012
    1,075
    Quote Originally Posted by ApolloS3 View Post
    Jordan
    Also you can change the PCV yourself, I think its about £40 and easy peasy to do. Airbox off, take off the old one, give the pipes a flush with petrol a bit of oil on the gasket and pop the new one on:
    Your revs do look PCV-ish, does it settle down at all? The whine could be your belt screeching ... if it's due its change get it done ASAP!
    Other than that the garage can fit you a new PCV cheapy-cheap. Cheap part, quick job.
    This is only based on my experience with my PCV going, other people will know better
    Lovegroover likes this.
    ApolloS3's Avatar
    Jul 2012
    73
    Thanks mate, videos should play now.
    ApolloS3's Avatar
    Jul 2012
    73
    Just seen this on youtube, identical problem:
    wuta3's Avatar
    Jul 2012
    1,075
    Yea just get the garage to do it when they do your belt (which id be more concerned about). Its a 10 min job really and £40 part.
    Sounds like a cat puuurring that vid.
    ApolloS3's Avatar
    Jul 2012
    73
    Update: Just in case anyone else searching gets the same issues and finds this thread: Changed the PCV valve to the newer revision (next one up from mine) and the problem is completely fixed, no erratic idle, no auto revving, no squeal and no whistle when driving.
    The car also feels incredibly more powerful, its like some life has been put back into it, very happy for a cheap £40 fix, the PCV must have been on its way out for a few months now.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    yes, pcv is really weak point on these engines. but at least it's a cheaper fix.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    TDI140's Avatar
    May 2011
    1,364
    I had this on my TDI was turbo outlet hose has a minuscule hole in it so get boost leak test done for peace of mind
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Jan 2005
    Colchester, Essex
    147
    Anyone know the PCV part no.?
    Just tried to order one from Audi but the guy was as much use as a handbrake in a canoe, so i'm not sure he's got me the right bit coming. 06F129101N is what i've got coming?
    BTW my car is a Oct '08 S3
    Jan 2005
    Colchester, Essex
    147
    Have found that is the correct part no. above for anyone who wants to know.
    Also found that if your oil filler cap isn't done up correctly - 1/4 turn instead of 1/2 turn it will provide these symptoms. Thank god for Audi-sport.net would have been an embarrasing garage visit. lol
    Abo-S4's Avatar
    Mar 2010
    Scotland
    Big thanks from me !!
    Quote Originally Posted by Lovegroover View Post
    I just had to say Thanks for all your info in this thread.
    I just bought my 2009 Audi S3 last Wednesday and I absolutely love it, but after having it for less than a week, I started getting the erratic idling problems.
    I was considering taking it back to the Garage, then I though let's have a quick Google search first and this thread came up.
    So I called my local Audi parts depot and gave them the part number from your post, they confirmed it was the right one for my car and they had it in stock.
    I picked it up today and swapped it over myself in less than 15 mins, my car now runs like a dream.
    Thanks again,
    Steve
  1. High pitch sqweal when turning right......... Possibly wheel bearing?
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2013, 19:30
  2. high pitch noise when driving? it gets higher pitched with engine revs
    By danonline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2011, 19:23
  3. Judder at Idle and Small clunk when cold...
    By chrisash32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2010, 23:46
  4. High pitched squeal..when turning?
    By GibletsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2008, 11:39
  5. High pitched noise when starting from cold
    By ajek in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th November 2004, 15:00
