JMB RetrofitsBadger5
Results 1 to 18 of 18
    Dec 2012
    244
    Milltek fitment question for Sportback owners
    I've had my milltek on a few weeks but can't help but notice the pipes sit in the recess a lot! Plus they are on the pi55 when u look at them lol. Is this how everyone's look, only reason I never bothered to ask before was my original always sat a bit wonky what do you's think?
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    Dec 2011
    237
    They should sit level and straight are you sure you haven't got a 3 door version as they are shorter in length than the sportback version could be the Reason why its sitting back in from your bumper or it mite just need a little adjusting as the Joints might be slid on too far
    TDI140's Avatar
    May 2011
    1,355
    For the tdi sportback milltek said thats the gttdi mk5 5 door and 3 door is the same as the sportback audi a3 one but on the 3 door a3 its slightly shorter, but if your not happy with it jack the car up from behind and loosed the clamp where the back box connects onto the centre pipe and pull the back box out a bit and clamp down as hard as you can so its secure then pull tail pipes out a bit aswel to as far as they go and clamps tight again, should sit better by doing that 30minute job, also if you think tail pipes are angles more than usual you have to swap tail pipes over as you may have wrong one on wrong side
    ive purposely left mine slight hidden on my tdi due to dirty black smoke from remap lol but wipes clean with dry tissue wouldnt ever buy any other exhaust system again, my car doesnt even sound like a diesel under throttle
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    TDI140's Avatar
    May 2011
    1,355
    I say yours sits quite nicely same sort of distance out of the valance as mine on my sportback
    Dec 2012
    244
    Well I did think it was a 3 door when I realised but the numbers tally up with the one for the Sportback.
    I can't pull it out any further as it starts to hit on the subframe!
    So if I try an push the tips out it'll make that touch the subframe.
    What do you mean about swapping the tips over? Mine are welded on to the back box.
    TDI140's Avatar
    May 2011
    1,355
    Your tips are welded ?? :-/ thats weird how old is the system ?
    my tail pipes can be adjusted to sit further in or out, i personally think your exhaust sits nicely mate
    Mar 2011
    14
    Probably the tail pipes are for the 3door......had a similar problem and the reason was that the dealer, not miltek, had send me the 3 door version of the tail pipes.
    Dec 2012
    244
    The system is brand new. Here's how the tail pipes look
    And here's how it look from the side to give a better view of how far in it sits
    The back box has the stamp on it for a Sportback so if it is a 3 door box milltek have stamped the wrong badge on?
    If that's how other people's Sportback systems sit I'm not bothered but my mates Polo GTI system sticks out flush with the surround so you can just see the milltek stamps on the top of the pipes
    TDI140's Avatar
    May 2011
    1,355
    If his tail pipes are wrong it means the whole back box is wrong as the tail pipes are welded to the back box
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    The new models can be adjusted. On the older ones the tips are welded and can't be adjusted.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Mar 2011
    14
    Is the rear Sline? Could that make the difference?
    Dec 2012
    244
    So we are saying that this is somehow old stock and they make a newer system where the tips can be adjusted?
    It's an S3 so presume milltek made it with the S3 rear bumper?
    TDI140's Avatar
    May 2011
    1,355
    Milltek for the s line and sport is same system as i had mine fitted when i had sport bumper on rear but then changed for s line bumper, the s3 system is a totally different one to the a3's, as said above yours is the older system thats why exhaust tips cant be adjusted mines only about 4 months old
    Dec 2012
    244
    Milltek will be getting an email! Only bought it a month ago.
    Dec 2012
    244
    Milltek got back to me and said all the Sportback systems have the welded tips? But you say yours are adjustable?
    They want to see more pictures of the hangers so sent that off to them today, hopefully get a response tomorrow.
    TDI140's Avatar
    May 2011
    1,355
    Well heres my tail pipes taken off as i was adjusting them
    image.jpg This is before i adjusted them so they look a bit bent in the picture lol
    Dec 2012
    244
    He must of meant the S3 Sportback system is welded, good job you were able to adjust yours lol
    TDI140's Avatar
    May 2011
    1,355
    Yh maybe they are just welded on the petrol models due to generating more heat and possibly spitting flames etc
  1. A few questions for S5 owners please
    By monster_munch in forum A5/S5/RS5 Forum
    Last Post: 28th July 2012, 10:45
  2. Question for S3 owners out there..
    By brasiliangringo in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2012, 15:41
  3. Hello and a question for quattro owners
    By 2.0 8v in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th March 2010, 01:47
  4. Question for S3 owners....
    By Ash B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th August 2009, 17:50
  5. A few questions for new owner....
    By sprout99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st January 2008, 13:19
