AH FabricationsChris Nott
    Apr 2013
    100
    A3 2.0tdi sport lowering tips for the rear??
    My 3 door a3 sport sits high on the rear, could i get away with jist diffrent springs? Maybe of a diffrent spec car? Thanks
    Rom
    Rom's Avatar
    May 2010
    Bristol
    442
    Only thing lower than sport is sline or s3. Not sure either fit, sure someone can confirm.
    That or buy some Eibachs or H+Rs.
    VCDS - Hex-Can-USB - Bristol Area
    Toyota Pro Tech - PM me if you need something done!
    2004 A3 TDi Sport
    - Bose, Leather / Alcantaras, Cruise, Eibach Sportlines, S Line Facelift
    Full Paint Correction
    To Do - Lamin X, Tints, Wheels
    Past Cars
    Peugeot 205 Gti Mi16 - Main love affair - Build Thread
    Honda CRX SiR - Short lived - Build Thread
    BMW E46 330d Sport
    Peugeot 306 Hdi DTurbo
    VW Gold MK4 TDi
    Vauxhall Nova SR - First car!
    vorney's Avatar
    May 2011
    leeds
    121
    just put a full set of h&r 45mm springs on my a3 sport. sits well and rides 100% better.
    a3glenn's Avatar
    6th gear
    milton keynes
    94
    i have and a3 se, had it lowered 30mm (im sure it was more though) but the front sat about 10mm higher than i wanted so got my self a
    set of h&R 45-50mm lowering springs.
    i did the front and i would say it might have gone down a small amount, i fitted the rears and after fitting, the rear end looked back at standard (would say it was a good inch higher) now i know they say the will settle but not that much, so fitted old lowering springs back on,
    have to say you can feel the improvement on the front though.
  1. Advice Please :- Whats the best lowering springs for the a4? and how low do they go?
    By jambofuz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th April 2012, 08:55
  2. Is there a straight swap silicone TIP for the APY engine?
    By Benjiman46 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2012, 12:44
  3. can you buy a single rubber seal for the rear brake piston ?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th May 2009, 09:28
  4. Protective Film for the rear bumper
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2007, 16:48
  5. Electric windows for the rear help
    By docurley in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th December 2003, 11:43
