AH FabricationsJMB Retrofits
    Sep 2009
    81
    Question Part number for A3 8P 3 door glovebox gas strut?
    Hi all,
    The glovebox in my 2004 A3 8P 3 door drops down sharply when you operate the open handle. Is it possible to replace just the gas strut rather than the entire glovebox unit and if so does anyone know the part number?
    Cheers,
    Jimbo
    A3 8P 2.0 TDI (140ps) Sport DSG
    Factory | Sunroof | Xenons | Cruise | Parking sensors | Headlight washers | Red Vienna leather | Bose | Piano black inserts | Heated Seats | Electric lumbar | Front Arm Rest
    Retro | S-Line roof spoiler | 18" RS6 | Angel Tuning remap | ITG Performance Air Filter | RNS-E + Bluetooth | Tomtom iPhone car kit | Removable tow bar
    In progress | Ashtray deletion | Factory matched tints
    Wish list | MFSW | Auto wipers/lights | Auto dimming mirrors | Folding mirrors
    JPK
    May 2012
    278
    As far as I'm aware the part is not sold separately. Most people just repair the existing one.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    Sep 2009
    81
    Quote Originally Posted by JPK View Post
    Any advice on the procedure?
    27,113
    Yes, remove glovebox, separate the broken part from the brake element, super glue the 2 parts together on the lid to give it a position, then coat the break in araldite going up/down the shaft as such or some 2 pack resin, allow to harden for 24 hours, whilst this is drying open the tube/brake element, whack some grease inside, work back/forth, then refit the tube lid & test in hand its moving, then refit to the glovebox, make sure the lid of the tube is fitted the right way round or the glovebox light (if fitted) wont work properly.
    27,113
    Also if you cant be bothered to repair, I have some gloveboxes available with working arms etc
    Sep 2009
    81
    Thank you very much for the instructions. How much is a glovebox? If I can afford it then it might make more sense than trying to repair it.
  1. Part Number for 5 door S line rear spoiler light
    By ~RS~ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st April 2012, 00:08
  2. Part number for the clips that hold the door cards on
    By Adamantium in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 12:37
  3. Anyone got a part number for cabin filter door 2.0tdi
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2010, 20:15
  4. Part numbers for door pillars
    By jb111s in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2009, 16:36
  5. Part Number for Door Lock Mechanism/Sensor
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2006, 21:52
