Badger5Sky Insurance
    Feb 2013
    51
    Replacing the small 5W bulb (side light/DRL) on the left side
    Hello everyone,
    A few days ago I switched on the car and got the "Side light/daylight running light, left side" message. I checked it, and it's correct - it stopped working. It's no big deal (normally it's hard to even see it's not working), but the beeep every time I start the engine is bugging me.
    However, I find it impossible to replace it.
    I replaced the right side equivalent in 1 minute flat, but the left side bulb socket is so hard to approach. I spent an hour digging to try to take it out, and I just can't.
    Either my hands are too big (they are big), or there's a trick I don't know. Do you have a tip? Maybe a tool to use?
    Thanks in advance.
    Aug 2012
    Aberdeen
    42
    I managed to get my hands in for one side, just, to replace it. The other side I just wouldn't bend that way. I used a screwdriver to prise out the bulb assembly from the holder. Gently of course as not to damage the plastic, just takes a bit of wiggling and it does come out.
    You then should have the bulb and holder out but still attached to the power cables, but there should be enough excess wire to let you get in and change it.
    Feb 2013
    51
    I tried another time, but then just drove to a car electrician and he changed the bulb with some pliers and stuff. It's ridiculous that they made changing a bulb so difficult.. :-)
  1. Side Light Bulb replacement
    By Jon Clare in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 3rd November 2012, 17:35
  2. DRL out on drivers side, how the hell do you replace it???
    By robapp1985 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th July 2012, 19:11
  3. Side light bulb replacement.
    By Danman1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2012, 18:04
  4. LED side lights and canbus wiring - side lights on all the time
    By M7R in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th June 2010, 10:41
  5. A3 02 plate with Xenons, 501 the correct side light bulb?!
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2008, 05:03
