JMB RetrofitsBadger5
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    Adjusting Rear Coilovers...
    Hi all,
    Decided I wanted to go a bit lower on the rear of my A3. I've got AP coilovers so the adjuster is at the top but when using the C spanner to adjust it, the whole thing spins including the black plate at the top! I've read that this is a common problem but not read of a solution.
    Any tips on how to adjust it? It's annoying me that the fronts are so easy to adjust but the backs are a massive polavour!
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Quote Originally Posted by leeds2592 View Post
    Hi all,
    Slightly late reply here, but ...
    Remove the adjuster and drill a hole in the side of the threaded piece (at the base, not in the threads!). You will now be able to insert a screwdriver into the hole and prevent them from turning when you adjust them. I had to do this on my FK's.
    Jun 2011
    Greenock
    214
    I put my adjuster at the bottom and bolted it to the swing arm, worked for me but is a bit of a nightmare if you want to adjust the ride height.
    Although it is only one bolt and you can get easy access to it.
  1. how to adjust rear coilovers???
    By dplovin in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2011, 12:25
  2. How low does it go without the rear Coilover adjusters in?
    By dougie175 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2011, 22:33
  3. rear coilover adjusters
    By luke1987 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th June 2010, 17:22
  4. Rear coilovers adjusting
    By chesney in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2007, 17:45
  5. adjusting rear coilovers..
    By HD_A3 in forum Handling
    Last Post: 5th November 2007, 05:28
