AH FabricationsEM Tuning
    May 2013
    215
    Quote Originally Posted by stan 1 View Post
    anybody on here no if the boot lid can be ajusted had a look at the top to see if there were any
    bolts etc cant see anything, its a 2007 audi s3 8p, are the boot lids fixed and not able to ajust??
    one side of my lid is slightly higher than the other and doesnt sit over my light correctly??
    any help would be appreciated thanks??
    Last edited by wanton; 23rd June 2013 at 14:04. Reason: I am a fool and not reading the post properly
    27,126
    There are some bolts either side, there maybe room or adjustment, you'd need to have a look & undo 1 side slightly to see what movement they have.
    Assuming you've checked the light fitment itself initially, gaps all round same as other side, no damage?
    27,126
    They are bolted, I have a boot lid of the car here as it happens, there are lined markings that are usual for adjustment purposes & the holes appear to be elongated, 2 bolts each side, 1 inner/1 outer, just go have a look at yours, but definitely check everything else relevant 1st before adjusting the fixings.
    Mar 2011
    Cleveland
    995
    Doesn't the hatch have rubber screw-in-out stops on the bottom edge for levelling, the same as the bonnet?
  1. Avant boot lid non-closure
    By dan_b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2007, 00:56
  2. Rear lock plinth on boot lid (rust)
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2007, 20:26
  3. Rear boot lid spoiler
    By Lynas in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd February 2006, 21:15
  4. ETKA diagram needed for boot lid
    By cybrey in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2004, 11:54
