Chris NottVolks Autos
Like Tree1Likes
  • 1 Post By chinnyhill10
Thread: Help with cold start issue
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,040
    Firstly, since filter change/new intake my MPG is better. Now getting 30mpg if gentle.
    However, I have an odd cold-start issue. In the mornin, here's what happens:
    a) Turn engine over
    b) Rev dial takes about 1-second longer than normal to move ... it's on 0rpm even though the engine is running during that second
    c) The idle is a bit rough for half a second then settles to rev a bit high
    d) Needle wakes up, shows correct (but too high) 1100-1200 RPM
    e) Revs settle to 1000rpm before settling to 800rpm as normal.
    Warm starts are fine.
    Car drives fine otherwise. PCV is new-ish, been there and changed that. Fuel related? Seems odd that the dash needle is a bit laggy too but could be unrelated.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Oct 2012
    134
    Look at the battery. Mine was doing some odd things that seemed similar to a previous cold start problem related to the lift pump. Putting in a new battery cured it.
    These cars seem to be very sensitive to weak batteries it seems.
    wuta3 likes this.
  1. 2.5tdi cold starting issue
    By JimLoskot in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th August 2011, 03:31
  2. Cold start issue
    By Connor_scotland in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th January 2011, 10:02
  3. cold start issue tdi 130
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2011, 16:16
  4. Cold Start Issue......?
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2007, 14:48
  5. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
