EM TuningChris Nott
Results 1 to 17 of 17
Like Tree4Likes
  • 2 Post By voorhees
  • 1 Post By wuta3
  • 1 Post By david_phillips95
Thread: Fitted my Autotech internals!
    Dec 2012
    240
    Just thought I'd post up about fitting my internals, just need a bit of info.
    I fitted them on Friday and did the full pump strip an clean as autotech recommend and now it's all back together it seems louder, the pump that is.
    Now it could be because I've done the work I'm listening too much and this is normal. The car drives fine no problems under a heavy load and fine to the red line. Only standard software till I get my downpipe fitted.
    Did anyone else think theirs sounded louder? When the engines running if you put your ear to it you can hear the metallic sound of the piston really loudly.
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    They are much clattery 'er once the autotech kit is installed
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,852
    I'd say mine is but I can't hear it above the induction kit
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    418
    Good little thread, ill have to remember this when I fit mine in the coming months.
    Looks a relatively easy job just requires a clean atmosphere to work in. Got any tips on fitting it?
    Dec 2012
    240
    That's good to know! Thanks
    Tips for fitting: Remember which way every little bit came out. Take a few pics or video as you do it, wish I would of! Lol
    Or don't do the whole clean just remove the spring, 18mm nut and swap the piston, put back together job done, glad I cleaned mine out but to do it again it would be the easy way
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,852
    wuta3 and coreythorny like this.
    Mar 2013
    Leicestershire
    418
    Thanks for that!
    Only thing not clear is the collets but I presume when stripping the old internals down its apparant?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,852
    Just follow the destructions,do it in a clean room/sterile area and always use gloves and alcohol based cleaner,you don't want any contaminant's.
    Dec 2012
    240
    Make sure you do your research and see as many how to's you can, the autotech instructions for the rebuild has no pictures and basically says put it back together like this and it can be a tad confusing which way round parts go
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,852
    If your not au fait with it then leave it as H17ydl says
    Mar 2013
    Leicestershire
    418
    No I'm more than comfortable doing it, in a engineer so shouldn't be anything I've not seen or done before its just i take more care in my car than work
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,852
    Quote Originally Posted by coreythorny View Post
    Lmao
    Dec 2012
    240
    Same with me mate! Lol
    Mar 2013
    Leicestershire
    418
    Quote Originally Posted by H17YD L View Post
    The company pays the bill if it goes wrong at work, I have to pay the bill on my car
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,040
    I enjoy giving myself challenges that im more than likely to **** up, so rebuilding a HPFP should be fine. Yea, it'll be fine.
    voorhees likes this.
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    david_phillips95's Avatar
    Nov 2008
    538
    I can recall thinking mine was louder when I fitted the uprated pump. The uprated pumps require more force to operate so it would make sense for the operating noise to increase from OEM.
    Nothing to worry about...Enjoy S2+, I certainly did
    Dec 2012
    240
    It is a relief to hear this! When I first started it up I was trying to think what I could of done wrong. I was close to stripping it down until I went out an it drove ok so thought I'd check on here.
    Can't wait to get the 2+ software loaded!
  1. Apr uprated high pressure fuel pump or autotech internals
    By Craig Cull in forum For Sale/Wanted - Audi Parts
    Last Post: 29th May 2013, 00:35
  2. Autotech Pump & RS4 Fuel pressure regulator fitted @ Star Performance = :-)
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th December 2010, 17:30
  3. 300 miles on new Sachs Uprated clutch- too soon to fit an Autotech fuel pump?
    Last Post: 29th October 2010, 19:32
  4. Autotech upgraded fuel pump internals
    By Rabbit222 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2008, 17:07
