Sky InsuranceJMB Retrofits
Results 1 to 12 of 12
Thread: Coolant flush
    Jun 2013
    Cumbria
    202
    Coolant flush
    Hello I'm wanting to drain my coolant system and I think I've got an idea how to do it but not totally sure. Do I do the following...
    Put car on axle stands
    take off overflow cap
    Pull up the drain plug till its all come out then replace it
    pour in hot water till it reaches the max line
    Run the engine to warm and keep repeating
    is this correct or are there any guides?
    2003/2004 Audi A3 2.0 TDi Sport
    Lewis583's Avatar
    Mar 2010
    870
    Sounds about right. Don't forget to put your heaters on hot though and medium fan speed when running it up to temp. Not doing so can cause air locks.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Jun 2013
    Cumbria
    202
    I can't find this coolant drain anywhere :-/
    Apr 2013
    Aberdeenshire
    590
    Quote Originally Posted by Tommy53 View Post
    Thats because it doesn't have one unclip the lower hose.
    Jun 2013
    Cumbria
    202
    That's the drivers side one on the rad isn't it? Do I need to disconnect the intercooler pipe too as its in the way
    Apr 2013
    Aberdeenshire
    590
    It's on my passenger side but yours could be different watch out for air locks mine took ages to purge remove the cap when draining
    Jun 2013
    Cumbria
    202
    Sure this middle one is it. How do you purge it? Using heater matrix and driving?
    Apr 2013
    Aberdeenshire
    590
    Run it with cap off heating on stationery of course and squeeze large hoses to move air locks mine took a long time to purge.
    Jun 2013
    Cumbria
    202
    How can you be sure it's correctly purged? I'm getting hot air through all heaters and no bubbles are coming up + the coolants not dropping any more.. Is that correct? Temp gauge sits just below 90 now tho, little much coolant to water ?
    Apr 2013
    Aberdeenshire
    590
    Check your return pipe to the expansion tank has a good flow and keep an eye on it for a while as you may find your Poland level will drop as it bleeds .
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    741
    I changed my radiator to a cheap eBay one, that is far better than the OEM one (especially as it doesn't have a hole in it) and it killed the thermostat, so if you think that you've got all the air bubbles out and the temp doesn't get up to 90 then it might need a new thermostat.
    To burp the air bubbles out, as mentioned do it stationary with the cap off, then go for a fast drive, getting plenty of load on the engine (hills 3rd gear) and check every 5 minutes to see if it needs topping up. I found that it needed a little more once it had cooled down after a drive.
    My 2p.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Jun 2013
    Cumbria
    202
    Thanks all, seems to have settled now but I have a bottle of the coolant mixed with water in my car incase it drops
  1. coolant flush/change
    By mrjheeta in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th March 2011, 14:19
  2. Draining and flushing coolant system......
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2011, 16:39
  3. coolant flush
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th December 2010, 09:08
  4. S3 Coolant Flush
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2010, 13:11
  5. how much coolant/flushing system
    By audi18tdan in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2008, 12:55
