Chris NottJMB Retrofits
Results 1 to 7 of 7
    Sep 2011
    Reading
    50
    TDI Fuel leak after filter change
    Had my car serviced about 2k miles ago and noticed a tiny weep of derv but lately starting to smell and drip onto the floor.
    Guessing they not changed seal or bit of dirt.
    What's my options?
    Think it's too late to take back now.
    Jul 2010
    Merthyr Tydfil, United Kingdom
    881
    EDIT - is it leaking from the fuel filter itself??
    Had this happen to me twice.......
    Remove torx screws, replace seal and then gently tap the top in a star pattern until cover is flush with housing
    then put screws back in and tighten in star pattern. I find that garages rely on the screws to tighten everything down but they are simply too small to do that
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    Sep 2011
    Reading
    50
    Not to sure where its leaking from.
    Read that my car needs to be connected up to prim it 09 plate black edition.
    May chance the garage first?
    Jul 2010
    881
    Open the bonnet and start the car. The fuel filter is on the drivers side. You'll soon see if its leaking as it will start dribbling or shooting out!
    ive never had to prime the system. Simply replaced, turned the key and its fired up first time
    My Posh Golf
    Sep 2011
    Reading
    50
    It's not leaking but weeping runs fine just got derv under filter and now dripping on to the ground.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Depending on how they got the top off they may have bent the lid slightly so it doesn't seal properly (this happened on mine), look round the filter housing & check the gap around lid & bottom part. If you see any gaps squeeze it closed with a pair of grips & it should seal back up.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Sep 2011
    Reading
    50
    Garage Replaced seal and all ok!
  1. 2.5 V6 TDI Strange issue after cambelt change
    By wesmaster in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th May 2013, 23:12
  2. Audi A4 2.5 tdi, engine noisy after cambelt change
    By Dvsjayvip in forum The Welcome Section
    Last Post: 21st February 2013, 21:49
  3. Allroad 2.5 V6 TDI - Won't start after Fuel Filter change?
    By Magkakahalo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th February 2013, 16:53
  4. Oil leak after oil change
    By danger S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2011, 17:09
  5. Advice on changing A4 TDi Fuel Filter(pd engine, 115hp)
    By impster in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2009, 18:16
